activated tasks [message #70627] |
Tue, 14 July 2009 11:42  |
Originally posted by: seltmann.googlemail.com
is there a possibility to change the behavior of timetracking for an issue?
i would like to track the time that is spend for solving an issue while
im not using eclipse. So there is time im making calls and sitting in
meetings that times theoretically belong to the issue.
But the time doesnt count further when the eclipse window looses the
focus. so i would like to see an option that decides the behavior of
this feature. maybe the focus could be changed:
"window looses focus: stop" to "screensaver starts: stop" or "machine
suspends: stop"
any help appreciated
ciao
Ulf
Re: activated tasks [message #598157 is a reply to message #70627] |
Wed, 15 July 2009 03:11  |
Hi Ulf,
for me I solved this issue in the Preferences for Tasks, section Advanced:
Here you can disable the idle detection globally. Then as soon as you start the task, the time is
counting...
Not a perfect solution, but should work for the moment.
Would be happy to talk about a better design on a Mylyn bug, e.g.
- configure per repository
- configure per task (enable / disable idle detection)
Cheers, Jörg
On 07/14/09 17:42, Ulf Seltmann wrote:
> Hello,
> suspends: stop"
> ciao
> Ulf
FUDForum. Page generated in 0.04758 seconds
