Home » Eclipse Projects » Mylyn » Multiple editor windows for the same file when activating a task - Take 2
Multiple editor windows for the same file when activating a task - Take 2 [message #70534] Mon, 13 July 2009 03:26 Go to next message
Originally posted by: jeffreyz.q-free.com
I am *still* having the annoying problem where Mylyn opens *several*
identical editor windows for items in my task context. This occurs
whenever I activate a task.
I reported this problem this past January but no one replied. See:
http://dev.eclipse.org/newslists/news.eclipse.tools.mylyn/ms g01561.html
I still find it strange that no one else has noticed this. I have been
bothered by this problem for several *years*.
I now often have 5 or 6 identical editor windows for some files when I
activate a task. This makes it very difficult to organise my work -
something that Mylyn is supposed to help with in the first place!
As I explained in my previous cry for help, here is how I reproduce this
problem:
1. I have a single editor window for a file, e.g., named "foo.sql".
2. I deactivate the task. The current context disappears.
3. I later activate the task, which restores the context. At this point
there can be TWO editor windows opened for file "foo.sql".
If I repeat these steps over several days, I can end up with 5 or more
identical editor windows for some files. I may have only, say, 5 items
in my current context, but 15 open editor windows!
Perhaps I can clear up this problem by throwing away some
files/directories, but I don't want to start doing this indiscriminately.
Is there a way to "reset" Mylyn (whatever that means in practice)? Does
anyone have any suggestions as to what I can try?
Jeffrey
PS: I am running under the following configuration:
*** Date: Monday, 13 July 2009 09:23:19 Germany Time
*** Platform Details:
*** System properties:
awt.toolkit=sun.awt.windows.WToolkit
eclipse.application=org.eclipse.ui.ide.workbench
eclipse.buildId=I20090611-1540
eclipse.commands=-os
win32
-ws
win32
-arch
x86
-showsplash
C:\eclipse-3.5\eclipse\\plugins\org.eclipse.platform_3.3.200 .v200906111540\splash.bmp
-launcher
C:\eclipse-3.5\eclipse\eclipse.exe
-name
Eclipse
--launcher.library
C:\eclipse-3.5\eclipse\\plugins/org.eclipse.equinox.launcher .win32.win32.x86_1.0.200.v20090519\eclipse_1206.dll
-startup
C:\eclipse-3.5\eclipse\\plugins/org.eclipse.equinox.launcher _1.0.200.v20090520.jar
-product
org.eclipse.epp.package.reporting.product
-vm
C:\Program Files\Java\jre6\bin\client\jvm.dll
eclipse.home.location=file:/C:/eclipse-3.5/eclipse/
eclipse.launcher=C:\eclipse-3.5\eclipse\eclipse.exe
eclipse.p2.data.area=@config.dir/../p2/
eclipse.p2.profile=epp.package.reporting
eclipse.product=org.eclipse.epp.package.reporting.product
eclipse.startTime=1247469109997
eclipse.vm=C:\Program Files\Java\jre6\bin\client\jvm.dll
eclipse.vmargs=-Dosgi.requiredJavaVersion=1.5
-Xms40m
-Xmx512m
-XX:MaxPermSize=256m
-Djava.class.path=C:\eclipse-3.5\eclipse\\plugins/org.eclips e.equinox.launcher_1.0.200.v20090520.jar
file.encoding=Cp1252
file.encoding.pkg=sun.io
file.separator=\
java.awt.graphicsenv=sun.awt.Win32GraphicsEnvironment
java.awt.printerjob=sun.awt.windows.WPrinterJob
java.class.path=C:\eclipse-3.5\eclipse\\plugins/org.eclipse. equinox.launcher_1.0.200.v20090520.jar
java.class.version=50.0
java.endorsed.dirs=C:\Program Files\Java\jre6\lib\endorsed
java.ext.dirs=C:\Program Files\Java\jre6\lib\ext;C:\WINDOWS\Sun\Java\lib\ext
java.home=C:\Program Files\Java\jre6
java.io.tmpdir=C:\DOCUME~1\JeffreyZ\LOCALS~1\Temp\
java.library.path=C:\eclipse-3.5\eclipse;.;C:\WINDOWS\Sun\Ja va\bin;C:\WINDOWS\system32;C:\WINDOWS;C:/Program
Files/Java/jre6/bin/client;C:/Program
Files/Java/jre6/bin;C:\Perl\site\bin;C:\Perl\bin;C:\Program
Files\CollabNet Subversion
Client;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wb em;C:\Program
Files\Intel\WiFi\bin\;C:\Program
Files\ThinkPad\ConnectUtilities;C:\WINDOWS\system32\WindowsP owerShell\v1.0;C:\Program
Files\Common Files\Lenovo;C:\Program Files\ATI
Technologies\ATI.ACE\Core-Static;C:\Python26
java.runtime.name=Java(TM) SE Runtime Environment
java.runtime.version=1.6.0_13-b03
java.specification.name=Java Platform API Specification
java.specification.vendor=Sun Microsystems Inc.
java.specification.version=1.6
java.vendor.url=http://java.sun.com/
java.vendor.url.bug=http://java.sun.com/cgi-bin/bugreport.cgi
java.version=1.6.0_13
java.vm.info=mixed mode
java.vm.name=Java HotSpot(TM) Client VM
java.vm.specification.name=Java Virtual Machine Specification
java.vm.specification.vendor=Sun Microsystems Inc.
java.vm.specification.version=1.0
java.vm.vendor=Sun Microsystems Inc.
java.vm.version=11.3-b02
line.separator=
org.apache.commons.logging.Log=org.apache.commons.logging.im pl.NoOpLog
org.eclipse.equinox.launcher.splash.location=C:\eclipse-3.5\ eclipse\\plugins\org.eclipse.platform_3.3.200.v200906111540\ splash.bmp
org.eclipse.equinox.simpleconfigurator.configUrl=file:org.ec lipse.equinox.simpleconfigurator/bundles.info
org.eclipse.update.reconcile=false
org.osgi.framework.executionenvironment=OSGi/Minimum-1.0,OSG i/Minimum-1.1,OSGi/Minimum-1.2,JRE-1.1,J2SE-1.2,J2SE-1.3,J2S E-1.4,J2SE-1.5,JavaSE-1.6
org.osgi.framework.language=en
org.osgi.framework.os.name=WindowsXP
org.osgi.framework.os.version=5.1.0
org.osgi.framework.processor=x86
org.osgi.framework.system.packages=javax.accessibility,javax .activation,javax.activity,javax.annotation,javax.annotation .processing,javax.crypto,javax.crypto.interfaces,javax.crypt o.spec,javax.imageio,javax.imageio.event,javax.imageio.metad ata,javax.imageio.plugins.bmp,javax.imageio.plugins.jpeg,jav ax.imageio.spi,javax.imageio.stream,javax.jws,javax.jws.soap ,javax.lang.model,javax.lang.model.element,javax.lang.model. type,javax.lang.model.util,javax.management,javax.management .loading,javax.management.modelmbean,javax.management.monito r,javax.management.openmbean,javax.management.relation,javax .management.remote,javax.management.remote.rmi,javax.managem ent.timer,javax.naming,javax.naming.directory,javax.naming.e vent,javax.naming.ldap,javax.naming.spi,javax.net,javax.net. ssl,javax.print,javax.print.attribute,javax.print.attribute. standard,javax.print.event,javax.rmi,javax.rmi.CORBA,javax.r mi.ssl,javax.script,javax.security.auth,javax.security.auth. callback,javax.security.auth.
kerberos,javax.security.auth.login,javax.security.auth.spi,j avax.security.auth.x500,javax.security.cert,javax.security.s asl,javax.sound.midi,javax.sound.midi.spi,javax.sound.sample d,javax.sound.sampled.spi,javax.sql,javax.sql.rowset,javax.s ql.rowset.serial,javax.sql.rowset.spi,javax.swing,javax.swin g.border,javax.swing.colorchooser,javax.swing.event,javax.sw ing.filechooser,javax.swing.plaf,javax.swing.plaf.basic,java x.swing.plaf.metal,javax.swing.plaf.multi,javax.swing.plaf.s ynth,javax.swing.table,javax.swing.text,javax.swing.text.htm l,javax.swing.text.html.parser,javax.swing.text.rtf,javax.sw ing.tree,javax.swing.undo,javax.tools,javax.transaction,java x.transaction.xa,javax.xml,javax.xml.bind,javax.xml.bind.ann otation,javax.xml.bind.annotation.adapters,javax.xml.bind.at tachment,javax.xml.bind.helpers,javax.xml.bind.util,javax.xm l.crypto,javax.xml.crypto.dom,javax.xml.crypto.dsig,javax.xm l.crypto.dsig.dom,javax.xml.crypto.dsig.keyinfo,javax.xml.cr ypto.dsig.spec,javax.xml.datat
ype,javax.xml.namespace,javax.xml.parsers,javax.xml.soap,jav ax.xml.stream,javax.xml.stream.events,javax.xml.stream.util, javax.xml.transform,javax.xml.transform.dom,javax.xml.transf orm.sax,javax.xml.transform.stax,javax.xml.transform.stream, javax.xml.validation,javax.xml.ws,javax.xml.ws.handler,javax .xml.ws.handler.soap,javax.xml.ws.http,javax.xml.ws.soap,jav ax.xml.ws.spi,javax.xml.ws.wsaddressing,javax.xml.xpath,org. ietf.jgss,org.omg.CORBA,org.omg.CORBA_2_3,org.omg.CORBA_2_3. portable,org.omg.CORBA.DynAnyPackage,org.omg.CORBA.ORBPackag e,org.omg.CORBA.portable,org.omg.CORBA.TypeCodePackage,org.o mg.CosNaming,org.omg.CosNaming.NamingContextExtPackage,org.o mg.CosNaming.NamingContextPackage,org.omg.Dynamic,org.omg.Dy namicAny,org.omg.DynamicAny.DynAnyFactoryPackage,org.omg.Dyn amicAny.DynAnyPackage,org.omg.IOP,org.omg.IOP.CodecFactoryPa ckage,org.omg.IOP.CodecPackage,org.omg.Messaging,org.omg.Por tableInterceptor,org.omg.PortableInterceptor.ORBInitInfoPack age,org.omg.PortableServer,org
..omg.PortableServer.CurrentPackage,org.omg.PortableServer.P OAManagerPackage,org.omg.PortableServer.POAPackage,org.omg.P ortableServer.portable,org.omg.PortableServer.ServantLocator Package,org.omg.SendingContext,org.omg.stub.java.rmi,org.w3c .dom,org.w3c.dom.bootstrap,org.w3c.dom.css,org.w3c.dom.event s,org.w3c.dom.html,org.w3c.dom.ls,org.w3c.dom.ranges,org.w3c .dom.stylesheets,org.w3c.dom.traversal,org.w3c.dom.views,org .w3c.dom.xpath,org.xml.sax,org.xml.sax.ext,org.xml.sax.helpe rs
org.osgi.framework.vendor=Eclipse
org.osgi.framework.version=1.5.0
org.osgi.supports.framework.extension=true
org.osgi.supports.framework.fragment=true
org.osgi.supports.framework.requirebundle=true
os.arch=x86
os.name=Windows XP
os.version=5.1
osgi.arch=x86
osgi.bundles=reference:file:javax.transaction_1.1.1.v2009061 61300.jar,reference:file:org.eclipse.persistence.jpa.equinox .weaving_1.1.2.v20090612-r4475.jar,reference:file: org.eclipse.equinox.simpleconfigurator_1.0.100.v20090520-190 5.jar @1:start
osgi.bundles.defaultStartLevel=4
osgi.bundlestore=C:\eclipse-3.5\eclipse\configuration\org.ec lipse.osgi\bundles
osgi.configuration.area=file:/C:/eclipse-3.5/eclipse/configu ration/
osgi.framework=file:/c:/eclipse-3.5/eclipse/plugins/org.ecli pse.osgi_3.5.0.v20090520.jar
osgi.framework.extensions=reference:file:javax.transaction_1 .1.1.v200906161300.jar,reference:file:org.eclipse.persistenc e.jpa.equinox.weaving_1.1.2.v20090612-r4475.jar
osgi.framework.shape=jar
osgi.framework.version=3.5.0.v20090520
osgi.frameworkClassPath=.,
file:c:/eclipse-3.5/eclipse/plugins/javax.transaction_1.1.1. v200906161300.jar,
file:c:/eclipse-3.5/eclipse/plugins/org.eclipse.persistence. jpa.equinox.weaving_1.1.2.v20090612-r4475.jar
osgi.install.area=file:/C:/eclipse-3.5/eclipse/
osgi.instance.area=file:/C:/Documents and Settings/JeffreyZ/workspace-3.5/
osgi.instance.area.default=file:/C:/Documents and
Settings/JeffreyZ/workspace/
osgi.logfile=C:\Documents and Settings\JeffreyZ\workspace-3.5\.metadata\.log
osgi.manifest.cache=C:\eclipse-3.5\eclipse\configuration\org .eclipse.osgi\manifests
osgi.nl=en_GB
osgi.os=win32
osgi.splashLocation=C:\eclipse-3.5\eclipse\\plugins\org.ecli pse.platform_3.3.200.v200906111540\splash.bmp
osgi.splashPath=platform:/base/plugins/org.eclipse.platform
osgi.syspath=c:\eclipse-3.5\eclipse\plugins
osgi.tracefile=C:\Documents and
Settings\JeffreyZ\workspace-3.5\.metadata\trace.log
osgi.ws=win32
path.separator=;
sun.arch.data.model=32
sun.boot.class.path=C:\Program
Files\Java\jre6\lib\resources.jar;C:\Program
Files\Java\jre6\lib\rt.jar;C:\Program
Files\Java\jre6\lib\sunrsasign.jar;C:\Program
Files\Java\jre6\lib\jsse.jar;C:\Program
Files\Java\jre6\lib\jce.jar;C:\Program
Files\Java\jre6\lib\charsets.jar;C:\Program Files\Java\jre6\classes
sun.boot.library.path=C:\Program Files\Java\jre6\bin
sun.cpu.endian=little
sun.cpu.isalist=pentium_pro+mmx pentium_pro pentium+mmx pentium i486
i386 i86
sun.desktop=windows
sun.io.unicode.encoding=UnicodeLittle
sun.jnu.encoding=Cp1252
sun.management.compiler=HotSpot Client Compiler
sun.os.patch.level=Service Pack 3
user.country=GB
user.dir=C:\Documents and Settings\JeffreyZ
user.home=C:\Documents and Settings\JeffreyZ
user.language=en
user.name=JeffreyZ
user.timezone=Europe/Berlin
user.variant=
*** Features:
org.eclipse.birt (2.5.0.v20090607-9ODS6GD7wmMtz-DbWuHKMt_6VlSF)
"Business Intelligence and Reporting Tools"
org.eclipse.birt.chart.cshelp (2.5.0.v20090402-34-7w311A1728) "BIRT
Chart Context-sensitive Help"
org.eclipse.birt.cshelp (2.5.0.v20090402-34-7w311A1728) "BIRT
org.eclipse.birt.doc (2.5.0.v20090521-34-7w311A1726) "BIRT Documentation"
org.eclipse.birt.example (2.5.0.v20090611-7F7Y-DZRDEBDrGg) "BIRT Example"
org.eclipse.birt.report.designer.editor.xml.wtp
(2.5.0.v20090611-7m9a4FTy215N3qZ5UkRE) "BIRT Advanced XML Editor Plug-in"
org.eclipse.cvs (1.1.100.v20090514-7E79FEc9BJ99r9YFR6JOEF) "Eclipse CVS
Client"
org.eclipse.datatools.common.doc.user
(1.7.0.v200906111100-26-311A16321A3557) "Data Tools Platform User
Documentation"
org.eclipse.datatools.connectivity.doc.user
(1.7.0.v200906111100-37D-7733L3D753L7BBF) "Data Tools Platform
Connectivity User Documentation"
org.eclipse.datatools.connectivity.feature
(1.7.0.v200906050400-7B7OAGEn1XeXjC4wj6KETrSOP8) "Data Tools Platform
Connectivity Plug-in"
org.eclipse.datatools.connectivity.oda.designer.feature
(1.7.0.v200906050400-7E7C6DZRDEBDsDSDijc) "DTP ODA Designer UI Framework
Plug-in"
org.eclipse.datatools.connectivity.oda.feature
(1.7.0.v200906050400-7H791CcNBC0BjDNBddV) "DTP Open Data Access"
org.eclipse.datatools.doc.user (1.7.0.v200906111100-47C-8w95ENAJ69EHJF7)
"Data Tool Platform User Documentation"
org.eclipse.datatools.enablement.apache.derby.feature
(1.7.0.v200906050400-7768bBmKDLfMjGqHEHL7PAB) "High-level Sybase
Enablement Plug-in"
org.eclipse.datatools.enablement.feature
(1.7.0.v200906050400-7J8i0BWwPJNaz-Fe15qs9q203H-b) "Eclipse Data Tools
Platform Enablement"
org.eclipse.datatools.enablement.hsqldb.feature
(1.7.0.v200906050400-67B0AqGBJVKbEmF3FJ7PAB) "Eclipse Data Tools
org.eclipse.datatools.enablement.ibm.feature
(1.7.0.v200906050400-7F47HFC7sRTNSjRsTNRR) "Eclipse Data Tools Platform
Enablement"
org.eclipse.datatools.enablement.ingres.feature
(1.7.0.v200906050400-540AkF77g7VACAJJM) "Eclipse Data Tools Platform
Enablement"
org.eclipse.datatools.enablement.jdbc.feature
(1.7.0.v200906050400-4-29oB55W5N6A6O9A) "High-level Sybase Enablement
Plug-in"
org.eclipse.datatools.enablement.jdt.feature
(1.7.0.v200906050400-2-07w311A17131A11) "Data Tools Platform
Connectivity JDT Extension Plug-in"
org.eclipse.datatools.enablement.msft.feature
(1.7.0.v200906050400-542AkF77g7V7F7g77) "Eclipse Data Tools Platform
Enablement"
org.eclipse.datatools.enablement.mysql.feature
(1.7.0.v200906050400-546AkF77g7V7F7g77) "Eclipse Data Tools Platform
Enablement"
org.eclipse.datatools.enablement.oda.designer.feature
(1.7.0.v200906050400-33-8s733L3D6C47AG) "Eclipse Data Tools Platform XML
ODA Designer"
org.eclipse.datatools.enablement.oda.feature
(1.7.0.v200906050400-7A7T5DZRDEADiKjEbOs) "Eclipse Data Tools Platform
XML ODA Runtime Driver"
org.eclipse.datatools.enablement.oracle.feature
(1.7.0.v200906050400-548aAkF77g7V7F7g77) "Eclipse Data Tools Platform
Enablement"
org.eclipse.datatools.enablement.postgresql.feature
Enablement"
org.eclipse.datatools.enablement.sap.feature
(1.7.0.v200906050400-540AkF77g7V7F7g77) "Eclipse Data Tools Platform
Enablement"
org.eclipse.datatools.enablement.sqlite.feature
(1.7.0.v200906050400-541AkF77g7V7F7g77) "Eclipse Data Tools Platform
Enablement"
org.eclipse.datatools.enablement.sybase.feature
(1.7.0.v200906050400-7E45F9NiNWvOOVpNfUR) "High-level Sybase Enablement
Plug-in"
org.eclipse.datatools.intro (1.7.0.v200906050400-26-7w311A17142212)
"Eclipse Data Tools Platform Intro Plug-in"
org.eclipse.datatools.modelbase.feature
(1.7.0.v200906050400-77-3CcNBC0BkBNNN_0) "Eclipse Data Tools Platform
SQLModel Plug-in"
org.eclipse.datatools.sqldevtools.ddlgen.feature
(1.7.0.v200906050400-7A-0F7RZHIXI6HZXnHX) "Eclipse Data Tools Platform
FE UI Plug-in"
org.eclipse.datatools.sqldevtools.feature
(1.7.0.v200906050400-7N7q-FDr_gSWLQCJJODUlz-1btbZ) "Eclipse Data Tools
Platform SQL Tools Common UI Plug-in"
org.eclipse.datatools.sqldevtools.parsers.feature
(1.7.0.v200906050400-602BgJ99q9_9OGXFJ) "Eclipse Data Tools Platform SQL
Parser Plugin"
org.eclipse.datatools.sqltools.doc.user
(1.7.0.v200906111100-37D-7733L3D753L7BBF) "Data Tools Platform SQL Tools
User Documentation"
org.eclipse.draw2d (3.5.0.v20090422-2346-44-7w311A163902622) "Graphical
Editing Framework Draw2d"
org.eclipse.emf (2.5.0.v200906151043) "EMF - Eclipse Modeling Framework
Runtime and Tools"
org.eclipse.emf.codegen (2.5.0.v200906151043) "EMF Code Generation"
org.eclipse.emf.codegen.ecore (2.5.0.v200906151043) "EMF Ecore Code
Generator"
org.eclipse.emf.codegen.ecore.ui (2.5.0.v200906151043) "EMF Ecore Code
Generator UI"
org.eclipse.emf.codegen.ui (2.4.0.v200906151043) "EMF Code Generation UI"
org.eclipse.emf.common (2.5.0.v200906151043) "EMF Common"
org.eclipse.emf.common.ui (2.5.0.v200906151043) "EMF Common UI"
org.eclipse.emf.converter (2.5.0.v200906151043) "EMF Model Converter"
org.eclipse.emf.databinding (1.1.0.v200906151043) "EMF Data Binding"
org.eclipse.emf.databinding.edit (1.1.0.v200906151043) "EMF Edit Data
Binding"
org.eclipse.emf.ecore (2.5.0.v200906151043) "EMF Ecore"
org.eclipse.emf.ecore.edit (2.5.0.v200906151043) "EMF Ecore Edit"
org.eclipse.emf.ecore.editor (2.5.0.v200906151043) "EMF Sample Ecore Editor"
org.eclipse.emf.edit (2.5.0.v200906151043) "EMF Edit"
org.eclipse.emf.edit.ui (2.5.0.v200906151043) "EMF Edit UI"
org.eclipse.emf.mapping (2.5.0.v200906151043) "EMF Mapping"
org.eclipse.emf.mapping.ecore (2.5.0.v200906151043) "EMF Ecore Mapping"
org.eclipse.emf.mapping.ecore.editor (2.5.0.v200906151043) "EMF Ecore
Mapping Editor"
org.eclipse.emf.mapping.ui (2.5.0.v200906151043) "EMF Mapping UI"
org.eclipse.epp.package.reporting.feature (1.2.0.20090615-0858) "EPP
Reporting Bundle"
org.eclipse.gef (3.5.0.v20090422-2346-7779-8192B6696L3ABD43733)
"Graphical Editing Framework GEF"
org.eclipse.help (1.1.0.v20090602-7e7eFAlFEx2XZoYqwI68e2F) "Help System
Base"
org.eclipse.jdt (3.5.0.v20090527-2000-7r88FEeFJePyvYeA33DjZ_c1) "Eclipse
Java Development Tools"
org.eclipse.jpt.eclipselink.feature
(2.2.0.v200905310000-65A7AkF77g7SGH7997) "Dali Java Persistence Tools -
EclipseLink Support"
org.eclipse.jpt.feature (2.2.0.v200906100220-7L7OAFFBBoPR9QNdMUt_f)
"Dali Java Persistence Tools"
org.eclipse.jst.common.fproj.enablement.jdt
(3.1.0.v200905220328-377-8s733L3F3J3D33) "Eclipse Faceted Project
Framework JDT Enablement"
org.eclipse.jst.enterprise_ui.feature
(3.1.0.v200905242144-7_7EGr_FQRwRZSME08aqRiT1Skap) "Eclipse Java EE
Developer Tools"
org.eclipse.jst.ws.axis2tools.feature
(1.1.0.v200905242110-78-FBpDZRDE6FdPdLYYe) "Axis2 Tools"
org.eclipse.mylyn_feature (3.2.0.v20090617-0100-e3x) "Mylyn"
org.eclipse.mylyn.bugzilla_feature (3.2.0.v20090617-0100-e3x) "Mylyn"
org.eclipse.mylyn.context_feature (3.2.0.v20090617-0100-e3x) "Mylyn"
org.eclipse.mylyn.ide_feature (3.2.0.v20090617-0100-e3x) "Mylyn"
org.eclipse.mylyn.java_feature (3.2.0.v20090617-0100-e3x) "Mylyn"
org.eclipse.mylyn.jira_feature (3.2.0.v20090617-0100-e3x) "Mylyn"
org.eclipse.mylyn.team_feature (3.2.0.v20090617-0100-e3x) "Mylyn"
org.eclipse.mylyn.trac_feature (3.2.0.v20090617-0100-e3x) "Mylyn"
org.eclipse.mylyn.wikitext_feature (1.1.0.v20090617-0100-e3x) "Mylyn"
org.eclipse.pde (3.5.0.v20090123-7Z7_F8NFE-z0VXhWiu-8Qb95) "PDE"
org.eclipse.persistence.jpa (1.1.2.v20090612-r4475) "EclipseLink JPA"
org.eclipse.persistence.moxy (1.1.2.v20090612-r4475) "EclipseLink MOXy"
org.eclipse.persistence.sdo (1.1.2.v20090612-r4475) "EclipseLink SDO"
org.eclipse.platform (3.5.0.v20090611a-9gEeG1HFtQcmRThO4O3aR_fqSMvJR2sJ)
"Eclipse Platform"
org.eclipse.rcp (3.5.0.v20090519-9SA0FwxFv6x089WEf-TWh11) "Eclipse RCP"
org.eclipse.rse (3.1.0.v200905272300-7L5A78wqaCHMdrOqK3DvjpYKCnp3)
"Remote System Explorer End-User Runtime"
org.eclipse.rse.core (3.1.0.v200905272300-7a7CEoFC7sRTNS_oZt3fk) "RSE Core"
org.eclipse.rse.dstore (3.1.0.v200905272300-7L6EoEVVFGMFvQtVaPU) "RSE
DStore Services"
org.eclipse.rse.ftp (3.0.100.v200905272300-780A79oB55W5KBQBD9D) "RSE FTP
Service"
org.eclipse.rse.local (2.1.100.v200905272300-7B4EoBgJ99r9YJhJO99) "RSE
Local Services"
org.eclipse.rse.ssh (3.0.0.v200905272300-7A2BgAkF77g7RFZFJ77) "RSE SSH
Services"
org.eclipse.rse.telnet (2.2.0.v200905272300-773-AkF77g7RFZFIBF) "RSE
Telnet Service"
org.eclipse.rse.terminals (1.0.0.v200905272300-77--9uC6FSANEbEMAF4522)
"RSE Terminals UI"
org.eclipse.rse.useractions (1.1.100.v200905272300-31A78s733L3D7H7933)
"Remote System Explorer User Actions"
org.eclipse.team.svn (0.7.8.I20090506-1500) "Subversive SVN Team
Provider (Incubation)"
org.eclipse.team.svn.mylyn (0.7.8.I20090506-1500) "Subversive
Integration for the Mylyn Project (Incubation)"
org.eclipse.tm.terminal (3.0.0.v200905272300-4--7w311A16383411) "Target
Management Terminal Widget"
org.eclipse.tm.terminal.ssh (2.0.100.v200905272300-3-8Z7w311A16383411)
"Target Management Terminal SSH Connector"
org.eclipse.tm.terminal.telnet
(2.0.100.v200905272300-3-8Z7w311A16383411) "Target Management Terminal
Telnet Connector"
org.eclipse.tm.terminal.view (2.0.100.v200905272300-3-8Z7w311A16383411)
"Target Management Terminal View"
org.eclipse.wst.common.fproj (3.1.0.v200906080522-377-8s733L3F3J3DAB)
"Eclipse Faceted Project Framework"
org.eclipse.wst.jsdt.feature (1.1.1.v200906091427-77-FGBCcNBC-BeMcEeOm)
"JavaScript Developer Tools "
org.eclipse.wst.web_ui.feature
(3.1.0.v200905242131-7R77FShEVw2xUGpF1LiNxdVAELXy) "Eclipse Web
Developer Tools"
org.eclipse.wst.xml_ui.feature
(3.1.0.v200905240756-7H6FMVDxtkM-5OgPGKK4xQocS5AL) "Eclipse XML Editors
and Tools"
org.eclipse.wst.xsl.feature
(1.0.0.v200905242203-7R7T7IFIhIehWfz064pz0YX1) "Eclipse XSL Developer Tools"
org.polarion.eclipse.team.svn.connector (2.2.0.I20090505-1500)
"Subversive SVN Connectors"
org.polarion.eclipse.team.svn.connector.svnkit16 (2.2.0.I20090505-1500)
"Subversive SVN 1.6 SVN Kit Connector"
*** Plug-in Registry:
com.ibm.icu (4.0.1.v20090415) "International Components for Unicode for
Java (ICU4J)" [Active]
com.jcraft.jsch (0.1.41.v200903070017) "JSch" [Resolved]
com.lowagie.itext (1.5.4.v20090608) "Lowagie Itext" [Resolved]
commonj.sdo (2.1.1.v200905221342) "SDO API" [Starting]
java_cup.runtime (0.10.0.v200803061811) "Java Cup" [Resolved]
javax.activation (1.1.0.v200806101325) "Apache Geronimo Activation
Plug-in" [Resolved]
javax.activation (1.1.0.v200905021805) "Apache Geronimo Activation
Plug-in" [Resolved]
javax.mail (1.4.0.v200804091730) "Javax Mail Plug-in" [Resolved]
javax.mail (1.4.0.v200905040518) "Javax Mail Plug-in" [Resolved]
javax.persistence (1.99.0.v200906021518) "JPA 1.0 - Extended for OSGi
(1.99)" [Resolved]
javax.servlet (2.5.0.v200806031605) "Servlet API Bundle" [Resolved]
javax.servlet (2.4.0.v200806031604) "Servlet API Bundle" [Resolved]
javax.servlet.jsp (2.0.0.v200806031607) "Java Server Pages API Bundle"
[Resolved]
javax.transaction (1.1.1.v200906161300) "jta 1.1 spec" [Resolved]
javax.wsdl (1.5.1.v200806030408) "WSDL4J" [Resolved]
javax.wsdl (1.6.2.v200806030405) "WSDL4J" [Resolved]
javax.xml (1.3.4.v200902170245) "JAXP XML" [Resolved]
javax.xml.bind (2.0.0.v20080604-1500) "JAXB" [Resolved]
javax.xml.rpc (1.1.0.v200905122109) "JAX-RPC" [Resolved]
javax.xml.soap (1.2.0.v200905122109) "SAAJ" [Resolved]
javax.xml.stream (1.0.1.v200903100845) "Java XML Streaming API" [Resolved]
net.sourceforge.lpg.lpgjavaruntime (1.1.0.v200803061910) "SourceForge
LPG" [Resolved]
org.apache.ant (1.7.1.v20090120-1145) "Apache Ant" [Resolved]
org.apache.axis (1.4.0.v200905122109) "Apache Web Services" [Resolved]
org.apache.batik.bridge (1.6.0.v200805290154) "Apache Batik
Bridge/GVT/Scripting" [Resolved]
org.apache.batik.css (1.6.0.v200805290154) "Apache Batik CSS" [Resolved]
org.apache.batik.dom (1.6.0.v200805290154) "Apache Batik DOM" [Resolved]
org.apache.batik.dom.svg (1.6.0.v200805290154) "Apache Batik SVG DOM"
[Resolved]
org.apache.batik.ext.awt (1.6.0.v200805290154) "Apache Batik AWT
Utilities" [Resolved]
org.apache.batik.extension (1.6.0.v200805290154) "Apache Batik
Extension" [Resolved]
org.apache.batik.parser (1.6.0.v200805290154) "Apache Batik Parser"
[Resolved]
org.apache.batik.pdf (1.6.0.v200806031500) "Apache Batik PDF" [Resolved]
org.apache.batik.svggen (1.6.0.v200805290154) "Apache Batik SVG
Generation" [Resolved]
org.apache.batik.swing (1.6.0.v200805290154) "Apache Batik Swing" [Resolved]
org.apache.batik.transcoder (1.6.0.v200805290154) "Apache Batik
Transcoder" [Resolved]
org.apache.batik.util (1.6.0.v200805290154) "Apache Batik Utilities"
[Resolved]
org.apache.batik.util.gui (1.6.0.v200805290154) "Apache Batik GUI
org.apache.batik.xml (1.6.0.v200805290154) "Apache Batik XML" [Resolved]
org.apache.bcel (5.2.0.v200803061811) "Apache BCEL" [Resolved]
org.apache.commons.codec (1.3.0.v20080530-1600) "Apache Commons Codec
Plug-in" [Resolved]
org.apache.commons.collections (3.2.0.v200803061811) "Apache Commons
Collections" [Resolved]
org.apache.commons.discovery (0.2.0.v200905122109) "Jakarta-Commons
Discovery" [Resolved]
org.apache.commons.el (1.0.0.v200806031608) "Apache Commons JSP 2.0
Expression Language Interpreter" [Resolved]
org.apache.commons.httpclient (3.1.0.v20080605-1935) "Apache Commons
Httpclient" [Resolved]
org.apache.commons.jxpath (1.2.0.v20080604-1500) "Apache Commons JXPath"
[Resolved]
org.apache.commons.lang (2.1.0.v200803061811) "Apache Jakarta Commons
Lang" [Resolved]
org.apache.commons.lang (2.3.0.v200803061910) "Apache Jakarta Commons
Lang" [Resolved]
org.apache.commons.logging (1.0.4.v200904062259) "Apache Commons Logging
Plug-in" [Resolved]
org.apache.commons.net (2.0.0.v200905272248) "Apache Commons Net" [Resolved]
org.apache.derby.core (10.3.1.4) "Apache Derby Core Plug-in for Eclipse"
[Starting]
org.apache.jasper (5.5.17.v200903231320) "Apache Jasper 2 Plug-in"
[Resolved]
org.apache.log4j (1.2.13.v200903072027) "Apache Jakarta log4j Plug-in"
[Resolved]
org.apache.lucene (1.9.1.v20080530-1600) "Apache Lucene" [Resolved]
org.apache.lucene.analysis (1.9.1.v20080530-1600) "Apache Lucene
Analysis" [Resolved]
org.apache.oro (2.0.8.v200903061218) "Apache Jakarta ORO" [Resolved]
org.apache.velocity (1.5.0.v200905192330) "Apache Velocity Plug-in"
[Resolved]
org.apache.ws.commons.util (1.0.0.v20081204) "WS Commons Util Plug-in"
[Resolved]
org.apache.wsil4j (1.0.0.v200901211807) "WSIL4J" [Resolved]
org.apache.xalan (2.7.1.v200905122109) "Xalan-Java" [Resolved]
org.apache.xerces (2.9.0.v200909240008) "Apache Xerces-J" [Resolved]
org.apache.xml.resolver (1.2.0.v200902170519) "Apache XmlResolver"
[Resolved]
org.apache.xml.serializer (2.7.1.v200902170519) "Apache XML Commons
Serializer" [Resolved]
org.apache.xmlrpc (3.0.0.v20080530-1550) "Apache XML-RPC Plug-in" [Resolved]
org.eclipse.ant.core (3.2.100.v20090520) "Ant Build Tool Core" [Starting]
org.eclipse.ant.ui (3.4.0.v20090520) "Ant UI" [Starting]
org.eclipse.birt (2.5.0.v20090615) "Business Intelligence and Reporting
Tools" [Resolved]
org.eclipse.birt.chart.cshelp (2.5.0.v20090617) "BIRT Chart
Context-sensitive Help" [Starting]
org.eclipse.birt.chart.device.extension (2.5.0.v20090514) "BIRT Chart
Device Extension(s)" [Starting]
org.eclipse.birt.chart.device.pdf (2.5.0.v20090326) "BIRT Chart Device
PDF Extension" [Starting]
org.eclipse.birt.chart.device.svg (2.5.0.v20090423) "BIRT Chart Device
SVG Extension" [Starting]
org.eclipse.birt.chart.device.swt (2.5.0.v20090514) "BIRT Chart Device
SWT Extension" [Starting]
org.eclipse.birt.chart.engine (2.5.0.v20090604) "BIRT Chart Engine"
[Starting]
org.eclipse.birt.chart.engine.extension (2.5.0.v20090527) "BIRT Chart
Engine Extension" [Starting]
org.eclipse.birt.chart.examples (2.5.0.v20090514) "BIRT Chart Examples
Plug-in" [Starting]
org.eclipse.birt.chart.reportitem (2.5.0.v20090514) "BIRT Chart-Report
Integration" [Starting]
org.eclipse.birt.chart.reportitem.ui (2.5.0.v20090531) "BIRT
Chart-Report UI Integration Plug-in" [Starting]
org.eclipse.birt.chart.ui (2.5.0.v20090604) "BIRT Chart Library UI
Plug-in" [Starting]
org.eclipse.birt.chart.ui.extension (2.5.0.v20090604) "BIRT Chart UI
org.eclipse.birt.core (2.5.0.v20090601) "BIRT Core Package" [Starting]
org.eclipse.birt.core.script.function (2.5.0.v20090611) "Function
Plug-in" [Starting]
org.eclipse.birt.core.ui (2.5.0.v20090326) "BIRT Core UI" [Starting]
org.eclipse.birt.cshelp (2.5.0.v20090617) "BIRT Context-sensitive Help"
[Starting]
org.eclipse.birt.data (2.5.0.v20090605) "BIRT Data Engine" [Starting]
org.eclipse.birt.data.aggregation (2.5.0.v20090605) "Build-in
Aggregation Plug-in" [Starting]
org.eclipse.birt.doc (2.5.0.v20090615) "BIRT Documentation" [Starting]
org.eclipse.birt.example (2.5.0.v20090615) "BIRT Example" [Resolved]
org.eclipse.birt.report.data.adapter (2.5.0.v20090605) "BIRT Data
Adapter" [Starting]
org.eclipse.birt.report.data.oda.jdbc (2.5.0.v20090605) "BIRT ODA-JDBC
Bridge Driver" [Starting]
org.eclipse.birt.report.data.oda.jdbc.dbprofile (2.5.0.v20090605) "JDBC
Databases Profile Data Source ODA Runtime Driver" [Starting]
org.eclipse.birt.report.data.oda.jdbc.dbprofile.sampledb
(2.5.0.v20090605) "BIRT Sample Database Connection Profile Plug-in"
[Starting]
org.eclipse.birt.report.data.oda.jdbc.dbprofile.ui (2.5.0.v20090605)
"JDBC Databases Profile Data Source ODA Designer" [Starting]
org.eclipse.birt.report.data.oda.jdbc.ui (2.5.0.v20090605) "BIRT JDBC UI
Plug-in" [Starting]
org.eclipse.birt.report.data.oda.sampledb (2.5.0.v20090605) "BIRT Sample
Database" [Starting]
org.eclipse.birt.report.data.oda.sampledb.ui (2.5.0.v20090605) "BIRT
Sample Database UI Plug-in" [Starting]
org.eclipse.birt.report.data.oda.xml (2.5.0.v20090605) "BIRT ODA-XML
Driver" [Starting]
org.eclipse.birt.report.data.oda.xml.ui (2.5.0.v20090615) "BIRT ODA XML
org.eclipse.birt.report.debug.core (2.5.0.v20090603) "BIRT Debug Core
Plug-in" [Resolved]
org.eclipse.birt.report.debug.ui (2.5.0.v20090603) "BIRT Debug UI
Plug-in" [Starting]
org.eclipse.birt.report.designer.core (2.5.0.v20090603) "BIRT Designer
Core" [Starting]
org.eclipse.birt.report.designer.samplereports (2.5.0.v20090615) "BIRT
Samplereports Plug-in" [Starting]
org.eclipse.birt.report.designer.ui (2.5.0.v20090603) "BIRT Designer UI"
[Starting]
org.eclipse.birt.report.designer.ui.cubebuilder (2.5.0.v20090603) "BIRT
Cube Builder Plug-in" [Starting]
org.eclipse.birt.report.designer.ui.data (2.5.0.v20090603) "BIRT
Designer Data Plug-in" [Starting]
org.eclipse.birt.report.designer.ui.editor.script (2.5.0.v20090603)
"BIRT Enhanced Script Editor Plug-in" [Starting]
org.eclipse.birt.report.designer.ui.editor.xml.wtp (2.5.0.v20090603)
"BIRT Advanced XML Editor Plug-in" [Starting]
org.eclipse.birt.report.designer.ui.editors (2.5.0.v20090603) "BIRT
MultipageEditor Extension Point Plug-in" [Starting]
org.eclipse.birt.report.designer.ui.editors.schematic (2.5.0.v20090603)
"BIRT Editors Plug-in" [Starting]
org.eclipse.birt.report.designer.ui.ide (2.5.0.v20090603) "BIRT Designer
UI for IDE" [Starting]
org.eclipse.birt.report.designer.ui.lib (2.5.0.v20090603) "BIRT Designer
UI for Library" [Starting]
org.eclipse.birt.report.designer.ui.lib.explorer (2.5.0.v20090603) "BIRT
Library Explorer Plug-in" [Starting]
org.eclipse.birt.report.designer.ui.preview.web (2.5.0.v20090603) "BIRT
Preview Plug-in" [Starting]
org.eclipse.birt.report.designer.ui.samples.ide (2.5.0.v20090603)
"Report Samples IDE Plug-in" [Starting]
org.eclipse.birt.report.designer.ui.samplesview (2.5.0.v20090603) "BIRT
Report Samples View Plug-in" [Starting]
org.eclipse.birt.report.designer.ui.views (2.5.0.v20090603) "BIRT UI
Views Plug-in" [Starting]
org.eclipse.birt.report.engine (2.5.0.v20090616) "BIRT Engine" [Starting]
org.eclipse.birt.report.engine.dataextraction (2.5.0.v20090611)
"Dataextraction Plug-in" [Starting]
org.eclipse.birt.report.engine.dataextraction.csv (2.5.0.v20090514) "CSV
Data Extraction Plug-in" [Starting]
org.eclipse.birt.report.engine.emitter.config (2.5.0.v20090608) "BIRT
Emitter Configuration Plug-in" [Starting]
org.eclipse.birt.report.engine.emitter.html (2.5.0.v20090601) "BIRT HTML
Emitter" [Starting]
org.eclipse.birt.report.engine.emitter.pdf (2.5.0.v20090601) "BIRT PDF
emitter" [Starting]
org.eclipse.birt.report.engine.emitter.postscript (2.5.0.v20090608)
"BIRT POSTSCRIPT emitter" [Resolved]
org.eclipse.birt.report.engine.emitter.ppt (2.5.0.v20090601) "BIRT PPT
emitter" [Starting]
org.eclipse.birt.report.engine.emitter.prototype.excel (2.5.0.v20090601)
"BIRT Excel emitter" [Starting]
org.eclipse.birt.report.engine.emitter.wpml (2.5.0.v20090601) "BIRT Word
emitter" [Starting]
org.eclipse.birt.report.engine.fonts (2.5.0.v20090615) "BIRT Engine
fonts" [Resolved]
org.eclipse.birt.report.item.crosstab.core (2.5.0.v20090603) "BIRT
Crosstab Plug-in" [Starting]
org.eclipse.birt.report.item.crosstab.ui (2.5.0.v20090603) "BIRT
Crosstab UI Plug-in" [Starting]
org.eclipse.birt.report.model (2.5.0.v20090605) "BIRT Model" [Starting]
org.eclipse.birt.report.model.adapter.oda (2.5.0.v20090531) "BIRT Model
ODA Adapter" [Starting]
org.eclipse.birt.report.viewer (2.5.0.v20090520) "BIRT Web Viewer"
[Starting]
org.eclipse.birt.resources (2.5.0.v20090616) "BIRT Resources Plug-in"
[Resolved]
org.eclipse.compare (3.5.0.I20090514-0808) "Compare Support" [Active]
org.eclipse.compare.core (3.5.0.I20090430-0408) "Core Compare Support"
[Starting]
org.eclipse.compare.win32 (1.0.0.I20090430-0408) "Compare Support for
Word" [Starting]
org.eclipse.core.boot (3.1.100.v20080218) "Core Boot" [Starting]
org.eclipse.core.commands (3.5.0.I20090525-2000) "Commands" [Resolved]
org.eclipse.core.contenttype (3.4.0.v20090429-1800) "Eclipse Content
Mechanism" [Active]
org.eclipse.core.databinding (1.2.0.I20090604-2000) "JFace Data Binding"
[Starting]
org.eclipse.core.databinding.beans (1.2.0.I20090525-2000) "JFace Data
Binding for JavaBeans" [Resolved]
org.eclipse.core.databinding.observable (1.2.0.I20090604-2000) "JFace
Data Binding Observables" [Active]
org.eclipse.core.databinding.property (1.2.0.I20090526-2000) "JFace Data
Binding" [Starting]
org.eclipse.core.expressions (3.4.100.v20090429-1800) "Expression
Language" [Active]
org.eclipse.core.filebuffers (3.5.0.v20090526-2000) "File Buffers" [Active]
org.eclipse.core.filesystem (1.2.0.v20090507) "Core File Systems" [Active]
org.eclipse.core.filesystem.win32.x86 (1.1.0.v20080604-1400) "Core File
System for Windows" [Resolved]
org.eclipse.core.jobs (3.4.100.v20090429-1800) "Eclipse Jobs Mechanism"
[Active]
org.eclipse.core.net (1.2.0.I20090522-1010) "Internet Connection
Management" [Active]
org.eclipse.core.net.win32.x86 (1.0.0.I20080909) "Proxy for Windows"
[Resolved]
org.eclipse.core.resources (3.5.0.v20090512) "Core Resource Management"
[Active]
org.eclipse.core.resources.compatibility (3.4.0.v20090505) "Core
Resource Management Compatibility Fragment" [Resolved]
org.eclipse.core.resources.win32.x86 (3.5.0.v20081020) "Core Resource
Management Win32 Fragment" [Resolved]
org.eclipse.core.runtime (3.5.0.v20090525) "Core Runtime" [Active]
org.eclipse.core.runtime.compatibility (3.2.0.v20090413) "Core Runtime
Plug-in Compatibility" [Active]
org.eclipse.core.runtime.compatibility.auth (3.2.100.v20090413)
"Authorization Compatibility Plug-in" [Active]
org.eclipse.core.runtime.compatibility.registry (3.2.200.v20090429-1800)
"Eclipse Registry Compatibility Fragment" [Resolved]
org.eclipse.core.variables (3.2.200.v20090521) "Core Variables" [Active]
org.eclipse.cvs (1.0.300.v200906111540) "Eclipse CVS Client" [Starting]
org.eclipse.datatools.common.doc.user (1.7.0.20090521092446) "Data Tools
Platform User Documentation" [Starting]
org.eclipse.datatools.connectivity (1.1.2.v200906020553) "Data Tools
Platform Connectivity Plug-in" [Starting]
org.eclipse.datatools.connectivity.apache.derby (1.0.100.v200906020900)
"Eclipse Data Tools Platform Derby Plug-in" [Starting]
org.eclipse.datatools.connectivity.apache.derby.dbdefinition
(1.0.2.v200906020900) "Eclipse Data Tools Platform Apache Derby Database
Definition" [Starting]
org.eclipse.datatools.connectivity.apache.derby.ui (1.0.1.v200906020900)
"Eclipse Data Tools Platform Apache Derby UI Plug-in" [Starting]
org.eclipse.datatools.connectivity.console.profile (1.0.0.v200906020553)
"DTP Connection Profiles Storage File Editor Plug-in" [Starting]
org.eclipse.datatools.connectivity.db.generic (1.0.1.v200906020900)
"Eclipse Data Tools Platform Generic DB Connectivity Plug-in" [Starting]
org.eclipse.datatools.connectivity.db.generic.ui (1.0.1.v200906020900)
"Eclipse Data Tools Platform Generic DB UI Plug-in" [Starting]
org.eclipse.datatools.connectivity.dbdefinition.genericJDBC
(1.0.1.v200906111145) "Eclipse Data Tools Platform DBDefinition Generic
JDBC Plug-in" [Starting]
org.eclipse.datatools.connectivity.doc.user (1.7.0.20090521092446) "Data
Tools Platform Connectivity User Documentation" [Starting]
org.eclipse.datatools.connectivity.doc.user.contexts
(1.7.0.20090521092446) "Data Tools Platform Connectivity User
Documentation for context-sensitive help" [Starting]
org.eclipse.datatools.connectivity.oda (3.2.0.v200905220445) "DTP Open
Data Access" [Starting]
org.eclipse.datatools.connectivity.oda.consumer (3.2.0.v200906020553)
"DTP ODA Consumer Helper Component Plug-in" [Starting]
org.eclipse.datatools.connectivity.oda.design (3.2.0.v200906020553) "DTP
ODA Design Session Model" [Starting]
org.eclipse.datatools.connectivity.oda.design.ui (3.2.0.v200906030238)
"DTP ODA Designer UI Framework Plug-in" [Starting]
org.eclipse.datatools.connectivity.oda.flatfile (3.1.0.v200906020553)
"Eclipse Data Tools Platform Flat File ODA Runtime Driver" [Starting]
org.eclipse.datatools.connectivity.oda.flatfile.ui (3.1.0.v200906020553)
"Eclipse Data Tools Platform Flat File ODA Designer" [Starting]
org.eclipse.datatools.connectivity.oda.profile (3.2.0.v200906020553)
"DTP ODA Connection Profile Framework Plug-in" [Starting]
org.eclipse.datatools.connectivity.oda.template.ui (3.2.0.v200906020553)
"DTP ODA New Plug-in Template Wizard" [Starting]
org.eclipse.datatools.connectivity.sqm.core (1.1.0.v200906020553)
"Eclipse Data Tools Platform SQM Core Plug-in" [Starting]
org.eclipse.datatools.connectivity.sqm.core.ui (1.1.100.v200906020553)
"Eclipse Data Tools Platform SQM UI Plug-in" [Starting]
org.eclipse.datatools.connectivity.sqm.server.ui (1.1.100.v200906020553)
"Eclipse Data Tools Platform Server UI Plug-in" [Starting]
org.eclipse.datatools.connectivity.ui (1.1.4.v200906020553) "Data Tools
Platform Connectivity UI Plug-in" [Starting]
org.eclipse.datatools.connectivity.ui.dse (1.1.3.v200906020553) "Eclipse
Data Tools Platform Data Source Explorer Plug-in" [Starting]
org.eclipse.datatools.doc.user (1.7.0.20090521092446) "Data Tool
org.eclipse.datatools.enablement.finfo (1.5.1.v200906020900) "Eclipse
Data Tools Platform Enablement" [Starting]
org.eclipse.datatools.enablement.hsqldb (1.0.0.v200906020900) "Eclipse
Data Tools Platform HSQLDB Enablement Plug-in" [Starting]
org.eclipse.datatools.enablement.hsqldb.dbdefinition
(1.0.0.v200906020900) "Eclipse Data Tools Platform HSQLDB Database
Definition Enablement Plug-in" [Starting]
org.eclipse.datatools.enablement.hsqldb.ui (1.0.0.v200906020900)
"Eclipse Data Tools Platform HSQLDB UI Enablement Plug-in" [Starting]
org.eclipse.datatools.enablement.ibm.db2.iseries (1.0.1.v200906020900)
"Eclipse Data Tools Platform IBM DB2 UDB iSeries Plug-in" [Starting]
org.eclipse.datatools.enablement.ibm.db2.iseries.dbdefinitio n
(1.0.3.v200906020900) "DB2 UDB iSeries Database Definition Plug-in"
[Starting]
org.eclipse.datatools.enablement.ibm.db2.iseries.ui
(1.0.0.v200906020900) "Eclipse Data Tools Platform IBM DB2 UDB UI
org.eclipse.datatools.enablement.ibm.db2.luw (1.0.1.v200906020900)
"Eclipse Data Tools Platform IBM DB2 UDB LUW Plug-in" [Starting]
org.eclipse.datatools.enablement.ibm.db2.luw.dbdefinition
(1.0.3.v200906020900) "Eclipse Data Tools Platform DB2 UDB Database
Definition Plug-in" [Starting]
org.eclipse.datatools.enablement.ibm.db2.luw.ui (1.0.1.v200906020900)
"Eclipse Data Tools Platform IBM DB2 UDB LUW UI Plug-in" [Starting]
org.eclipse.datatools.enablement.ibm.db2.zseries (1.0.1.v200906020900)
"Eclipse Data Tools Platform IBM DB2 UDB zSeries Plug-in" [Starting]
org.eclipse.datatools.enablement.ibm.db2.zseries.dbdefinitio n
(1.0.3.v200906020900) "DB2 UDB Database Definition Plug-in" [Starting]
org.eclipse.datatools.enablement.ibm.db2.zseries.ui
(1.0.0.v200906020900) "Eclipse Data Tools Platform IBM DB2 UDB zSeries
org.eclipse.datatools.enablement.ibm.informix (1.0.0.v200906020900)
"Eclipse Data Tools Platform Informix Plug-in" [Starting]
org.eclipse.datatools.enablement.ibm.informix.dbdefinition
(1.0.3.v200906020900) "Eclipse Data Tools Platform Informix Database
org.eclipse.datatools.enablement.ibm.informix.ui (1.0.1.v200906020900)
"Eclipse Data Tools Platform Informix UI Plug-in" [Starting]
org.eclipse.datatools.enablement.ibm.ui (1.0.0.v200906020900) "Eclipse
Data Tools Platform IBM UI Plug-in" [Starting]
org.eclipse.datatools.enablement.ingres (1.0.0.v200906111145) "Ingres
DTP Plug-in" [Starting]
org.eclipse.datatools.enablement.ingres.dbdefinition
(1.0.0.v200906111145) "Ingres DTP Database Definition Plug-in" [Starting]
org.eclipse.datatools.enablement.ingres.ui (1.0.0.v200906111145) "Ingres
DTP UI Plug-in" [Starting]
org.eclipse.datatools.enablement.jdt.classpath (1.0.1.v200906020900)
"Data Tools Platform Connectivity JDT Extension Plug-in" [Starting]
org.eclipse.datatools.enablement.msft.sqlserver (1.0.1.v200906020900)
"Eclipse Data Tools Platform Microsoft SQL Server Plug-in" [Starting]
org.eclipse.datatools.enablement.msft.sqlserver.dbdefinition
(1.0.0.v200906020900) "Eclipse Data Tools Platform SQL Server Database
org.eclipse.datatools.enablement.msft.sqlserver.ui (1.0.1.v200906020900)
"Eclipse Data Tools Platform Microsoft SQL Server UI Plug-in" [Starting]
org.eclipse.datatools.enablement.mysql (1.0.2.v200906020900) "Eclipse
Data Tools Platform MySQL Enablement Plug-in" [Starting]
org.eclipse.datatools.enablement.mysql.dbdefinition
(1.0.4.v200906020900) "Eclipse Data Tools Platform MySQL Database
org.eclipse.datatools.enablement.mysql.ui (1.0.0.v200906020900) "Eclipse
Data Tools Platform MySQL UI Plug-in" [Starting]
org.eclipse.datatools.enablement.oda.ws (1.2.0.v200906020900) "Eclipse
Data Tools Platform Web Services ODA Runtime Driver" [Starting]
org.eclipse.datatools.enablement.oda.ws.ui (1.2.0.v200906111145)
"Eclipse Data Tools Platform Web Services ODA Designer" [Starting]
org.eclipse.datatools.enablement.oda.xml (1.2.0.v200905231053) "Eclipse
Data Tools Platform XML ODA Runtime Driver" [Starting]
org.eclipse.datatools.enablement.oda.xml.ui (1.2.0.v200904280338)
"Eclipse Data Tools Platform XML ODA Designer" [Starting]
org.eclipse.datatools.enablement.oracle (1.0.0.v200906020900) "Eclipse
Data Tools Platform Oracle Plug-in" [Starting]
org.eclipse.datatools.enablement.oracle.dbdefinition
(1.0.100.v200906020900) "Eclipse Data Tools Platform Oracle Database
org.eclipse.datatools.enablement.oracle.ui (1.0.1.v200906020900)
"Eclipse Data Tools Platform Oracle UI Plug-in" [Starting]
org.eclipse.datatools.enablement.postgresql (1.0.1.v200906020900)
"PostgreSQL Connection Profile and Driver Template Plug-in" [Starting]
org.eclipse.datatools.enablement.postgresql.dbdefinition
(1.0.1.v200906020900) "PostgreSQL DB Definition" [Starting]
org.eclipse.datatools.enablement.postgresql.ui (1.0.0.v200906020900)
"PostgreSQL Connection Profile and Driver Template UI Plug-in" [Starting]
org.eclipse.datatools.enablement.sap.maxdb (1.0.0.v200906020900)
"Eclipse Data Tools Platform MaxDB Enablement Plug-in" [Starting]
org.eclipse.datatools.enablement.sap.maxdb.dbdefinition
(1.0.0.v200906020900) "Eclipse Data Tools Platform MaxDB Definition
Plug-in" [Starting]
org.eclipse.datatools.enablement.sap.maxdb.ui (1.0.0.v200906020900)
"Eclipse Data Tools Platform MaxDB UI Plug-in" [Starting]
org.eclipse.datatools.enablement.sqlite (1.0.0.v200906020900) "Eclipse
Data Tools Platform SQLite Enablement Plug-in" [Starting]
org.eclipse.datatools.enablement.sqlite.dbdefinition
(1.0.1.v200906020900) "Eclipse Data Tools Platform SQLite Database
org.eclipse.datatools.enablement.sqlite.ui (1.0.0.v200906020900)
"Eclipse Data Tools Platform SQLite UI Enablement Plug-in" [Starting]
org.eclipse.datatools.enablement.sybase (1.0.1.v200906020900)
"High-level Sybase Enablement Plug-in" [Starting]
org.eclipse.datatools.enablement.sybase.asa (1.0.1.v200906020900)
"Sybase ASA Plug-in" [Starting]
org.eclipse.datatools.enablement.sybase.asa.dbdefinition
(1.0.0.v200906020900) "Eclipse Data Tools Platform Sybase ASA Database
org.eclipse.datatools.enablement.sybase.asa.models (1.0.0.v200906020900)
"Sybase ASA SQL Model" [Starting]
org.eclipse.datatools.enablement.sybase.asa.schemaobjectedit or.examples
(2.5.0.200810071) "Sybase ASA Schema Object Editor" [Starting]
org.eclipse.datatools.enablement.sybase.asa.ui (1.0.1.v200906111145)
"Sybase ASA Connection Profile UI Plug-in" [Starting]
org.eclipse.datatools.enablement.sybase.ase (1.0.1.v200906020900)
"JDBC/Sybase ASE Connection Profile Plug-in" [Starting]
org.eclipse.datatools.enablement.sybase.ase.dbdefinition
(1.0.0.v200906020900) "Eclipse Data Tools Platform Sybase ASE Database
org.eclipse.datatools.enablement.sybase.ase.models (1.0.1.v200906020900)
"Sybase ASE Model Plug-in" [Starting]
org.eclipse.datatools.enablement.sybase.ase.ui (1.0.1.v200906020900)
"ASE Enablement UI Plug-in" [Starting]
org.eclipse.datatools.enablement.sybase.models (1.0.0.v200906020900)
"Sybase Model Plug-in" [Starting]
org.eclipse.datatools.enablement.sybase.ui (1.0.0.v200906090451) "Sybase
org.eclipse.datatools.help (1.5.0.v200906020553) "Data Tools Platform
Help Utilities" [Resolved]
org.eclipse.datatools.intro (1.7.0.v200906031101) "Eclipse Data Tools
Platform Intro Plug-in" [Resolved]
org.eclipse.datatools.modelbase.dbdefinition (1.0.1.v200906022249)
"Eclipse Data Tools Platform DBDefinition Model" [Starting]
org.eclipse.datatools.modelbase.derby (1.0.0.v200906020900) "Eclipse
Data Tools Platform Derby Model Plug-in" [Starting]
org.eclipse.datatools.modelbase.sql (1.0.2.v200906022249) "Eclipse Data
Tools Platform SQLModel Plug-in" [Starting]
org.eclipse.datatools.modelbase.sql.edit (1.0.0.v200906022249) "Eclipse
Data Tools Platform SQLModel Edit Plug-in" [Starting]
org.eclipse.datatools.modelbase.sql.query (1.0.1.v200906022249) "Eclipse
Data Tools Platform SQL Query Model Plugin" [Starting]
org.eclipse.datatools.modelbase.sql.query.edit (1.0.0.v200906022249)
"SQL Query Edit Support Plugin" [Starting]
org.eclipse.datatools.modelbase.sql.xml.query (1.0.0.v200906022249)
"Eclipse Data Tools Platform SQL XML Query Model Plugin" [Starting]
org.eclipse.datatools.oda.cshelp (1.1.0.v200906020553) "DTP ODA
org.eclipse.datatools.sqltools.common.ui (1.0.0.v200906022302) "Eclipse
Data Tools Platform SQL Tools Common UI Plug-in" [Starting]
org.eclipse.datatools.sqltools.data.core (1.1.0.v200906022302) "Data
Core Plugin" [Starting]
org.eclipse.datatools.sqltools.data.ui (1.1.1.v200906022302) "Data UI
Plugin" [Starting]
org.eclipse.datatools.sqltools.db.derby (1.0.0.v200906020900) "Eclipse
Data Tools Platform Derby SQL Tools Plug-in" [Starting]
org.eclipse.datatools.sqltools.db.derby.ui (1.0.0.v200906020900)
"Eclipse Data Tools Platform Derby SQL Tools UI Plug-in" [Starting]
org.eclipse.datatools.sqltools.db.generic (1.0.0.v200906020900) "Eclipse
Data Tools Platform SQL Tools Generic Database Plug-in" [Starting]
org.eclipse.datatools.sqltools.db.generic.ui (1.0.0.v200906020900)
"Eclipse Data Tools Platform SQL Tools Generic Database UI Plug-in"
[Starting]
org.eclipse.datatools.sqltools.ddlgen.ui (1.0.0.v200906022302) "Eclipse
Data Tools Platform FE UI Plug-in" [Starting]
org.eclipse.datatools.sqltools.debugger.core (1.0.0.v200906022302)
"Eclipse Data Tools Platform SQL Debugger Framework" [Starting]
org.eclipse.datatools.sqltools.debugger.core.ui (1.0.0.v200906022302)
"Eclipse Data Tools Platform SQL Debugger UI Framework" [Starting]
org.eclipse.datatools.sqltools.doc.user (1.7.0.20090521092446) "Data
Tools Platform SQL Tools User Documentation" [Starting]
org.eclipse.datatools.sqltools.doc.user.contexts (1.7.0.20090521092446)
"Data Tools Platform SQL Tools User Documentation for context-sensitive
help" [Starting]
org.eclipse.datatools.sqltools.editor.core (1.0.0.v200906022302)
"Eclipse Data Tools Platform SQL Editor Core Plug-in" [Starting]
org.eclipse.datatools.sqltools.editor.core.ui (1.0.0.v200906022302)
"Eclipse Data Tools Platform SQL Editor Core UI Plug-in" [Starting]
org.eclipse.datatools.sqltools.parsers.sql (1.0.1.v200906022302)
"Eclipse Data Tools Platform SQL Parser Plugin" [Starting]
org.eclipse.datatools.sqltools.parsers.sql.lexer (1.0.1.v200906030654)
"Eclipse Data Tools Platform Lexer Plug-in" [Starting]
org.eclipse.datatools.sqltools.parsers.sql.query (1.0.1.v200906022302)
"Eclipse Data Tools Platform SQL Query Parser Plugin" [Starting]
org.eclipse.datatools.sqltools.parsers.sql.xml.query
(1.0.0.v200906022302) "Eclipse Data Tools Platform SQL XML Query Parser
Plugin" [Starting]
org.eclipse.datatools.sqltools.plan (1.0.0.v200906022302) "Eclipse Data
Tools Platform SQL Execution Plan View Plug-in" [Starting]
org.eclipse.datatools.sqltools.result (1.0.0.v200906022302) "Eclipse
Data Tools Platform SQL Results View Plug-ins" [Starting]
org.eclipse.datatools.sqltools.result.ui (1.0.0.v200906022302) "Eclipse
Data Tools Platform SQL Results View UI Plug-in" [Starting]
org.eclipse.datatools.sqltools.routineeditor (1.0.0.v200906022302)
"Eclipse Data Tools Platform SQL Tools Routine Editor Plug-in" [Starting]
org.eclipse.datatools.sqltools.routineeditor.ui (1.0.0.v200906022302)
"Eclipse Data Tools Platform SQL Tools Routine Editor UI Plug-in" [Starting]
org.eclipse.datatools.sqltools.schemaobjecteditor (1.1.0.v200906022302)
"Schema Object Editor Plug-in" [Starting]
org.eclipse.datatools.sqltools.schemaobjecteditor.ui (1.1.0.200810071)
"Schema Object Editor Framework" [Starting]
org.eclipse.datatools.sqltools.schemaobjecteditor.ui.pages
(1.1.0.200810071) "Schema Object Editor Pages Plug-in" [Starting]
org.eclipse.datatools.sqltools.sql (1.0.0.v200906022302) "Eclipse Data
Tools Platform SQL Core Plug-in" [Starting]
org.eclipse.datatools.sqltools.sql.ui (1.0.0.v200906022302) "Eclipse
Data Tools Platform SQL Core UI Plug-in" [Starting]
org.eclipse.datatools.sqltools.sqlbuilder (1.0.0.v200906022302) "SQL
Builder" [Starting]
org.eclipse.datatools.sqltools.sqleditor (1.0.0.v200906022302) "Eclipse
Data Tools Platform SQL Editor" [Starting]
org.eclipse.datatools.sqltools.sqlscrapbook (1.0.0.v200906022302)
"Eclipse Data Tools Platform Sqlscrapbook Plug-in" [Starting]
org.eclipse.datatools.sqltools.tabledataeditor (1.0.0.v200906022302)
"Eclipse Data Tools Platform Table Data Editor Plug-in" [Starting]
org.eclipse.debug.core (3.5.0.v20090526-1600) "Debug Core" [Active]
org.eclipse.debug.ui (3.5.0.v20090603) "Debug UI" [Starting]
org.eclipse.draw2d (3.5.0.v20090528-1511) "Graphical Editing Framework
Draw2d" [Starting]
org.eclipse.dstore.core (3.1.0.v200906032235) "RSE DStore Core" [Starting]
org.eclipse.dstore.extra (2.1.100.v200905272300) "RSE DStore Platform
Support" [Starting]
org.eclipse.ecf (3.0.0.v20090604-1131) "Eclipse Communication Framework
(ECF)" [Active]
org.eclipse.ecf.filetransfer (3.0.0.v20090604-1131) "ECF Filetransfer
API" [Active]
org.eclipse.ecf.identity (3.0.0.v20090604-1131) "ECF Identity API" [Active]
org.eclipse.ecf.provider.filetransfer (3.0.0.v20090604-1131) "ECF
Filetransfer Provider" [Active]
org.eclipse.ecf.provider.filetransfer.httpclient (3.0.0.v20090604-1131)
"ECF HttpClient Filetransfer Provider" [Active]
org.eclipse.ecf.provider.filetransfer.httpclient.ssl
(1.0.0.v20090604-1131) "ECF HttpClient Filetransfer Provider" [Resolved]
org.eclipse.ecf.provider.filetransfer.ssl (1.0.0.v20090604-1131) "ECF
org.eclipse.ecf.ssl (1.0.0.v20090604-1131) "Eclipse Communication
Framework (ECF)" [Resolved]
Runtime and Tools" [Starting]
org.eclipse.emf.ant (2.4.0.v200906151043) "EMF Ant Tasks" [Starting]
[Starting]
Generator" [Starting]
Generator UI" [Starting]
org.eclipse.emf.codegen.ui (2.5.0.v200906151043) "EMF Code Generation
UI" [Starting]
org.eclipse.emf.common (2.5.0.v200906151043) "EMF Common" [Active]
org.eclipse.emf.common.ui (2.5.0.v200906151043) "EMF Common UI" [Active]
[Starting]
[Starting]
Binding" [Starting]
org.eclipse.emf.ecore (2.5.0.v200906151043) "EMF Ecore" [Active]
org.eclipse.emf.ecore.change (2.5.0.v200906151043) "EMF Change Model"
[Starting]
org.eclipse.emf.ecore.change.edit (2.5.0.v200906151043) "EMF Change
Edit" [Starting]
org.eclipse.emf.ecore.edit (2.5.0.v200906151043) "EMF Ecore Edit" [Starting]
Editor" [Starting]
org.eclipse.emf.ecore.xmi (2.5.0.v200906151043) "EMF XML/XMI
Persistence" [Active]
org.eclipse.emf.edit (2.5.0.v200906151043) "EMF Edit" [Active]
org.eclipse.emf.edit.ui (2.5.0.v200906151043) "EMF Edit UI" [Active]
org.eclipse.emf.exporter (2.5.0.v200906151043) "EMF Model Exporter"
[Starting]
org.eclipse.emf.importer (2.5.0.v200906151043) "EMF Model Importer"
[Starting]
org.eclipse.emf.importer.ecore (2.4.0.v200906151043) "EMF Ecore
Importer" [Starting]
org.eclipse.emf.importer.java (2.5.0.v200906151043) "EMF Annotated Java
Importer" [Sta
Re: Multiple editor windows for the same file when activating a task - Take 2 [message #70555 is a reply to message #70534] Mon, 13 July 2009 07:49 Go to previous message
Hi Jeffrey,
did you post a Mylyn bug? This is the best way to get your issue addressed.
At the moment is holiday time and some of the Mylyn guys may be on vacation.
They definitely look at the bug list, but may not browse the newsgroup everyday.
Cheers, Jörg
Re: Multiple editor windows for the same file when activating a task - Take 2 [message #598101 is a reply to message #70534] Mon, 13 July 2009 07:49 Go to previous message
Hi Jeffrey,
Cheers, Jörg
Previous Topic:Generic web template connector + auto-login
Next Topic:Code-Review plugin?
Current Time: Wed Nov 12 20:45:07 EST 2025
Powered by FUDForum. Page generated in 0.04056 seconds
