Writable files after CVS commit [message #70447] |
Wed, 11 June 2003 02:29  |
Originally posted by: marcincak.vsl.sk
I would like to ask two questions concerning CVS and 'edit':
1. in normal case when I am at the office and connected to CVS
repository it is perfect, that Eclipse sends edit command to server when I
try to edit a file and write-enables the file. But there are situations,
when I am with the notebook somewhere off and need to edit some file. I such
situation I just write-enable file manually (from the properties tab), but
when I return to the office both 'edit' and 'unedit' options are disabled
for the file. Is this a bug?
2. when I commit newly-added files to the CVS, Eclipse adds them to the
repository automatically, but after commit the files are still writable. For
me it is not good because files are writable and I am not marked as editor.
And again both 'edit' and 'unedit' actions for these files are disabled.
Even when I make them readonly (from properties tab; file by file, because
properties are disabled in multiple file selection) icon decorations still
shows 'little person' (writable) and I have to restart Eclipse.
peter.
Re: Writable files after CVS commit [message #72365 is a reply to message #70919] |
Thu, 12 June 2003 13:40  |
Thanks a lot Michael
"Michael Valenta" <Michael_Valenta@oti.com> wrote in message
news:3EE73CA6.9070709@oti.com...
> peter wrote:
> > Hi,
I
such
but
disabled
> Did you try to perform an 'edit' when you were disconnected. Performing
> an edit when you are disconnected should work but the notification to
> the server is held until you connect successfully. If this doesn't work,
> then there is a bug.
the
For
editor.
because
still
> This is a known issue
(https://bugs.eclipse.org/bugs/show_bug.cgi?id=36470)
FUDForum. Page generated in 0.04116 seconds
