Home » Eclipse Projects » Equinox » servlet.bridge.launcher build
servlet.bridge.launcher build [message #70360] Wed, 19 July 2006 15:55 Go to next message
Originally posted by: duncan.krebsnet.com
I'm a little bit of a newbie with ANT and have a quick question with the
webappBuilder.xml script in org.eclipse.equinox.servlet.bridge.launcher.
I'm trying to reuse the script in a different plugin but when in eclipse
when i try going to run as -> ant build on both the copy and the launcher
build script I'm getting an error message saying that it can not find the
pdeExportFeatures task. It sounds like this should be added to the ANT
classpath during a build in eclipse. Is there something I have to add
extra?
Re: servlet.bridge.launcher build [message #70383 is a reply to message #70360] Wed, 19 July 2006 16:07 Go to previous message
Oh how the little things make such big differences, in the ANT property
tab I checked the option to compile in the same JRE and it now works.
Previous Topic:Extension Points conversion to OSGI Service Registry
Next Topic:Getting reference to default ServletContext
Current Time: Mon Nov 10 02:40:45 EST 2025
Powered by FUDForum. Page generated in 0.25656 seconds
