[ATL] (EMF?) engine cannot find existing reference [message #70331] |
Wed, 02 January 2008 10:53  |
Originally posted by: r.c.ladan.tue.nl
I have a model which triggers the following exception.
Is this because the reference is defined multiple times in the model?
The element in question has an attribute 'id', for which the isID flag is true.
The error message, detailed version numbers, and the (meta)model can be found at
ftp://rene-ladan.nl/pub/work/ (anonymous login).
ATL : 2.0.0
Eclipse : 3.3.1.1 M20071023-1652
EMF : 2.3.1 20070925-2135
Rene
SEVERE: org.eclipse.emf.ecore.xmi.UnresolvedReferenceException: Unresolved reference '{20000000-0000-0000-0001-000000000007}'. (file:comet.scenario, 249, 106)
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl$1Diagnos ticWrappedException: org.eclipse.emf.ecore.xmi.UnresolvedReferenceException: Unresolved reference '{20000000-0000-0000-0001-000000000007}'. (file:comet.scenario, 249, 106)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.handleDe mandLoadException(ResourceSetImpl.java:316)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLo adHelper(ResourceSetImpl.java:275)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.getResou rce(ResourceSetImpl.java:398)
at org.eclipse.m2m.atl.drivers.emf4atl.ASMEMFModel.loadASMEMFMo del(ASMEMFModel.java:312)
at org.eclipse.m2m.atl.engine.AtlEMFModelHandler.loadModel(AtlE MFModelHandler.java:219)
at org.eclipse.m2m.atl.adt.launching.AtlRegularVM.loadModel(Atl RegularVM.java:220)
at org.eclipse.m2m.atl.adt.launching.AtlRegularVM.getSourceMode ls(AtlRegularVM.java:138)
at org.eclipse.m2m.atl.adt.launching.AtlRegularVM.runAtlLaunche r(AtlRegularVM.java:326)
at org.eclipse.m2m.atl.adt.launching.AtlRegularVM.runAtlLaunche r(AtlRegularVM.java:453)
at org.eclipse.m2m.atl.adt.launching.AtlRegularVM.launch(AtlReg ularVM.java:425)
at org.eclipse.m2m.atl.adt.launching.AtlLaunchConfigurationDele gate.launch(AtlLaunchConfigurationDelegate.java:35)
at org.eclipse.debug.internal.core.LaunchConfiguration.launch(L aunchConfiguration.java:766)
at org.eclipse.debug.internal.core.LaunchConfiguration.launch(L aunchConfiguration.java:608)
at org.eclipse.debug.internal.ui.DebugUIPlugin.buildAndLaunch(D ebugUIPlugin.java:899)
at org.eclipse.debug.internal.ui.DebugUIPlugin$7.run(DebugUIPlu gin.java:1102)
Caused by: org.eclipse.emf.ecore.xmi.UnresolvedReferenceException: Unresolved reference '{20000000-0000-0000-0001-000000000007}'. (file:comet.scenario, 249, 106)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.handleForwardRefer ences(XMLHandler.java:1092)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.endDocument(XMLHan dler.java:1168)
at com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser .endDocument(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentS cannerImpl.scanDocument(Unknown Source)
at com.sun.org.apache.xerces.internal.parsers.XML11Configuratio n.parse(Unknown Source)
at com.sun.org.apache.xerces.internal.parsers.XMLParser.parse(U nknown Source)
at com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser .parse(Unknown Source)
at com.sun.org.apache.xerces.internal.jaxp.SAXParserImpl$JAXPSA XParser.parse(Unknown Source)
at javax.xml.parsers.SAXParser.parse(Unknown Source)
at org.eclipse.emf.ecore.xmi.impl.XMLLoadImpl.load(XMLLoadImpl. java:179)
at org.eclipse.emf.ecore.xmi.impl.XMLResourceImpl.doLoad(XMLRes ourceImpl.java:180)
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(Resour ceImpl.java:1354)
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(Resour ceImpl.java:1155)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLo ad(ResourceSetImpl.java:256)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLo adHelper(ResourceSetImpl.java:271)
... 14 more
SEVERE: null
at org.eclipse.m2m.atl.adt.launching.AtlRegularVM.getSourceMode ls(AtlRegularVM.java:140)
Re: [ATL] (EMF?) engine cannot find existing reference [message #70680 is a reply to message #70331] |
Mon, 07 January 2008 08:44  |
Rene Ladan wrote:
Well, according to Ed Merks from the EMF newsgroup ATL should be the guilty party.
Are the 2.0.0 sources available somewhere? I can find the HEAD sources at
:pserver:anonymous@dev.eclipse.org :/cvsroot/modeling/HEAD/org.eclipse.m2m/org.eclipse.atl/plug ins/
but the Versions and Branches tags are empty for ATL.
> ATL : 2.0.0
> Rene
> at org.eclipse.core.internal.jobs.Worker.run(Worker.java:55)
> ... 14 more
> SEVERE: null
> java.lang.NullPointerException
FUDForum. Page generated in 0.24205 seconds
