Home » Language IDEs » Java Development Tools (JDT) » How can I define output folder if I define several different folders as source?
How can I define output folder if I define several different folders as source? [message #70144] Mon, 30 June 2003 10:07 Go to next message
Originally posted by: jannuslin.hotmail.com
hello everyone,
It's me again. I've got another question...
Say that I want to define several different folders as source on the
"source" tab of the "Java Build Path" page, how can I define "default
output folder"?
Thanks a million times...
Jannus
Re: How can I define output folder if I define several different folders as source? [message #70183 is a reply to message #70144] Mon, 30 June 2003 10:24 Go to previous message
I've got it..... it's actually vey easy. All I need to do is to check the
"Allow output folder for source folder" and then define respectively
output folders for each source folder.
Previous Topic:Java GUI's
Next Topic:Running PDE JUnit tests from command line (or as external Ant task)
Current Time: Sat Nov 08 13:17:17 EST 2025
Powered by FUDForum. Page generated in 0.03721 seconds
