| How rename worked in AJDT1.4.1 [message #69921] |
Wed, 28 March 2007 04:51  |
Originally posted by: diezhongdie.sjtu.edu.cn
The one of new features is that rename refactoring also works in AspectJ
program. Is there any references or guidelines about its implementation?
How to make it happen in AOP program?
With kind regards! Winnie
| Re: How rename worked in AJDT1.4.1 [message #69960 is a reply to message #69941] |
Wed, 28 March 2007 06:39  |
Thank you for your information. That helps me a lot
>> AspectJ
>> implementation?
> The class which implements the refactoring participant for type
> renames is AspectRenameParticipant.java in the
> org.eclipse.ajdt.internal.core.refactoring package (in the
> org.eclipse.ajdt.core plugin).
> Search the plugin.xml in this plugin to see how this rename
> participant is registered with the system.
> For information about accessing the AJDT source, see:
> http://www.eclipse.org/ajdt/developers.php#q:source
> Matt.
| Re: How rename worked in AJDT1.4.1 [message #596052 is a reply to message #69921] |
Wed, 28 March 2007 05:07  |
The class which implements the refactoring participant for type renames
Search the plugin.xml in this plugin to see how this rename participant
Matt.
| Re: How rename worked in AJDT1.4.1 [message #596064 is a reply to message #69941] |
>> AspectJ
>> implementation?
> Matt.
FUDForum. Page generated in 0.04234 seconds
