Home » Language IDEs » AspectJ » C/C++ Programs From Java using JNI
C/C++ Programs From Java using JNI [message #69898] Mon, 26 March 2007 06:45
Iam using Eclipse 3.2 in Linux. I try to create a programe in Java using
Eclipse, which one execute a function in C/C++. For that I am try to use
JNI methord in JAVA. When i try this, I get one error message,
Exception in thread "main" java.lang.UnsatisfiedLinkError: no TestHello in
java.library.path
at java.lang.ClassLoader.loadLibrary(ClassLoader.java:1682)
at java.lang.Runtime.loadLibrary0(Runtime.java:822)
at java.lang.System.loadLibrary(System.java:993)
at TestHello.<clinit>(TestHello.java:8)
Please help me to solve the error.
I create a Java project named TestHello and a class (default) named
TestHello, and the contents of the .java file is
class TestHello
public native void sayHello();
static
try
System.loadLibrary("TestHello");
catch(Exception e)
System.out.println("exc");
public static void main(String[] args)
TestHello h = new TestHello();
h.sayHello ();
and save the file. After that I convert this java project into a C
project through, right click on the project -> new -> others -> C ->
convert to a C/C++ Make Project. Then the Perspetive view into C/C++.
create a file named " TestHello.c " and the contents of the file is, and
save the file.
#include <jni.h>
#include "TestHello.h"
#include <stdio.h>
JNIEXPORT void JNICALL Java_TestHello_sayHello
(JNIEnv *env, jobject obj)
printf("Hello world!\n");
return;
Write click on the project and create a file named " Makefile " , contents
of the file is, and save.
#The space must be a tab, where the * is found ( replace the * and give
SINGLE TAB tab ( NO SPACE ) )
all : TestHello.so
TestHello.so : TestHello.c TestHello.h
* gcc TestHello.c -o TestHello.so -shared -I /usr/java/jdk1.6.0/include/
-I /usr/java/jdk1.6.0/include/linux
TestHello.h : TestHello.class
* javah -jni TestHello
clean :
* -del TestHello.h
* -del TestHello.class
* -del TestHello.so
After that, take the properties, and take the C/C++ Make Project. Uncheck
the Use Default option and give the command like " make -f Makefile " .
Check on the option , " Build on Resource save (Auto Build )" and give
the " Make Build Target " variable as " all ". And set " Apply " and " OK
After this you get a header file "TestHello.h" a .so file " TestHello.so "
and create a Binaries.
When i run this programe using : Run ->Run.... -> JavaApplication
then an errer message display like this "
java.library.path
Please help me for solving this problum.
Sabeesh C.S
Previous Topic:AJDT New Feature: Crosscutting Changes
Next Topic:How rename worked in AJDT1.4.1
Current Time: Wed Dec 03 01:58:01 EST 2025
Powered by FUDForum. Page generated in 0.02591 seconds
