Home » Language IDEs » Java Development Tools (JDT) » [ANN] JXTA development plug-in
[ANN] JXTA development plug-in [message #69728] Sun, 29 June 2003 17:10 Go to next message
Originally posted by: hgarcia.oogo.net
I would like to announce the availablity of a simple plug-in that will
allow you to build JXTA apps more conveniently. At the moment I packaged
all the necesary jars so that you can code without the much hassle.
The install and usage instructions are available at
http://eclipsesupport.jxta.org/servlets/ProjectHome
Please be advised that this is an ongoing project and that all and any
suggestion, comment or question are welcomed.
-H
Re: [ANN] JXTA development plug-in [message #1238911 is a reply to message #69728] Sun, 02 February 2014 16:29 Go to previous message
I am teamlead for the JXTA 2.8x release, and as we are preparing to shift the work on JXTA towards OSGI, through project Chaupal, I was wondering if you are willing to merge your plugin in the Chaupal environment. I have currently made some UI available for Eclipse -utilising the neat feature of equinox that you can run multiple peergroups in one IDE-, but more help would be appreciated.
Check out what I've done so far in:
http://java.dzone.com/articles/jxse-and-equinox-tutorial-part-1
And tell me what you think!
Kees
Previous Topic:Some unit tests fail after compiling JDT from source code
Next Topic:Instantiate a IVMInstall with same JRE as Eclipse is using?
Current Time: Sun Jun 29 06:57:54 EDT 2025
Powered by FUDForum. Page generated in 0.03395 seconds
