Home » Language IDEs » ServerTools (WTP) » Building from CVS
Building from CVS [message #69650] Fri, 28 January 2005 10:36 Go to next message
Originally posted by: alan.ljubljana.agtrz.com
(I've just installed WTP from zips of the site on OS X. I'm
unable to edit and XML file unless it is only contains a
handful of elements. This might be something that has been
fixed in CVS, or something I could fix myself...
But, now I see what WTP is supposed to look like.)
I build WTP for OS X from CVS. It took some tweaking.
When I run the eclipse in the build directory, I don't seen any
WTP features.
How do you work from CVS?
Basically, I checked out org.eclipse.wtp.releng into a directory
and ran ant -f cruise.xml. Now that is is successful, I don't
seen any XML, J2EE, Web, support in the build-current/eclipse
application.
Alan Gutierrez - alan@engrm.com
Re: Building from CVS [message #69689 is a reply to message #69650] Fri, 28 January 2005 12:33 Go to previous messageGo to next message
> WTP features.
> application.
Looking closer at the build directory, I see only wtp packages in the
built Eclipse. How do I go about building WST?
Do I now start that built Eclipse and pull the modeles from CVS via
eclipse? How do I go about using the built projects (eating my own
dogfood)?
Is there a better place to ask these questions?
Re: Building from CVS [message #69750 is a reply to message #69689] Sat, 29 January 2005 01:22 Go to previous messageGo to next message
Use these files to import all the projects in the HEAD (nightly builds) and
last integrations from the CVS.
Larry Isaacs provided them in the last post (subject="error in one class")
Emerson Cargnin
Floripa/Brazil
<alan@ljubljana.agtrz.com> escreveu na mensagem
news:slrncvkts7.u2g.alan@agtrz.com...
> > WTP features.
> > application.
> dogfood)?
Outgoing mail is certified Virus Free.
Checked by AVG anti-virus system (http://www.grisoft.com).
Version: 6.0.845 / Virus Database: 574 - Release Date: 25/1/2005
Re: Building from CVS [message #70195 is a reply to message #69750] Sun, 30 January 2005 14:16 Go to previous message
> builds) and last integrations from the CVS.
Emerson
I didn't understand your message. I went and pulled the common
plugins from the CVS repository using the repository view of
esclipe and they build correctly, so I thought I'd figured it out.
Now I see you've attached some files to this post. I'm going to
have to find a different news reader to get to them. Could you
please e-mail the attachment to alan@engrm.com ?
If not, that's okay.
I'll probably be back with questions.
Thank you.
Previous Topic:Missing javax packages
Next Topic:out.print in jsp editor
Current Time: Mon Nov 17 10:31:37 EST 2025
Powered by FUDForum. Page generated in 0.05530 seconds
