| Building from CVS [message #69650] |
Fri, 28 January 2005 10:36   |
Eclipse User  |
Originally posted by: alan.ljubljana.agtrz.com
(I've just installed WTP from zips of the site on OS X. I'm
        unable to edit and XML file unless it is only contains a
        handful of elements. This might be something that has been
        fixed in CVS, or something I could fix myself...
        But, now I see what WTP is supposed to look like.)
    I build WTP for OS X from CVS. It took some tweaking.
    When I run the eclipse in the build directory, I don't seen any
    WTP features.
    How do you work from CVS?
    Basically, I checked out org.eclipse.wtp.releng into a directory
    and ran ant -f cruise.xml. Now that is is successful, I don't
    seen any XML, J2EE, Web, support in the build-current/eclipse
    application.
Alan Gutierrez - alan@engrm.com
| Re: Building from CVS [message #69689 is a reply to message #69650] |
Fri, 28 January 2005 12:33    |
Eclipse User  |
>     WTP features.
>     application.
    Looking closer at the build directory, I see only wtp packages in the
    built Eclipse. How do I go about building WST?
    Do I now start that built Eclipse and pull the modeles from CVS via
    eclipse? How do I go about using the built projects (eating my own
    dogfood)?
    Is there a better place to ask these questions?
| Re: Building from CVS [message #69750 is a reply to message #69689] |
Sat, 29 January 2005 01:22    |
Eclipse User  |
Use these files to import all the projects in the HEAD (nightly builds) and
last integrations from the CVS.
Larry Isaacs provided them in the last post (subject="error in one class")
Emerson Cargnin
Floripa/Brazil
<alan@ljubljana.agtrz.com> escreveu na mensagem
news:slrncvkts7.u2g.alan@agtrz.com...
> >     WTP features.
> >     application.
>     dogfood)?
Outgoing mail is certified Virus Free.
Checked by AVG anti-virus system (http://www.grisoft.com).
Version: 6.0.845 / Virus Database: 574 - Release Date: 25/1/2005
| Re: Building from CVS [message #70195 is a reply to message #69750] |
Sun, 30 January 2005 14:16   |
Eclipse User  |
> builds) and last integrations from the CVS.
    Emerson
    I didn't understand your message. I went and pulled the common
    plugins from the CVS repository using the repository view of
    esclipe and they build correctly, so I thought I'd figured it out.
    Now I see you've attached some files to this post. I'm going to
    have to find a different news reader to get to them. Could you
    please e-mail the attachment to alan@engrm.com ?
    If not, that's okay.
    I'll probably be back with questions.
    Thank you.
FUDForum. Page generated in 0.29303 seconds
