Home » Language IDEs » C / C++ IDE (CDT) » executing binaries under Linux
executing binaries under Linux [message #69605] Fri, 09 May 2003 11:38
Hi all,
I'm running Eclipse 2.0.2 with the 3/27 nightly build (I believe) of
CDT on a RH 8.0 Linux box. When I build a program, and then try to
execute it from inside Eclipse (using open with->default editor, which
works on Windows platforms) it tries to open up the binary in a window
instead of executing it. Is this the expected behavior, or is there some
other way to run the program in a new terminal window?
Josh
Previous Topic:not possible to debug
Next Topic:How to add existing Visual C++ 6.0 to CDT?
Current Time: Tue Nov 18 04:12:04 EST 2025
Powered by FUDForum. Page generated in 0.03662 seconds
