Home » Archived » Test and Performance Tools Platform (TPTP) » HTTP Test: error converting .rec file in .testsuite file
| HTTP Test: error converting .rec file in .testsuite file [message #69497] |
Fri, 05 May 2006 05:50  |
Originally posted by: lorenzobenvenuti.grupposervizi.it
Hi all,
I've got the following issue while trying to test my web application
using TPTP
(I tried both v4.1 and v4.2): I can successfully record a sequence of HTTP
calls, but I receive an error while converting the .rec file in a
..testsuite file.
The editor complaints about an invalid input and, watching the logs, I
found that
the resulting .testsuite file is a corrupted zip (it has just the
header, no data).
Everything works fine if I record some random web navigation, but I
obtain the
error when trying my Macromedia (or Adobe, if you prefer) Flex (a Java
based RIA
framework, for those who don't know) web app.
A test I made was to try the Macromedia Flex Explorer (a showcase of all
Flex
features) available at
http://www.macromedia.com/go/flexapp_codeexplorer
Everything fine in this case. If I deploy the same application on my Tomcat
(both 4.1.30 and 5.0.28), TPTP is unable to perform the conversion
between .rec
and .testsuite files. I tried to comment parts of the .rec file and
finally I
found the calls responsible of the TPTP failure: the issue seems to
be concerning a particular type of POST calls made from Flex (Content-type:
application/x-amf), but I can't see what's wrong whit them (there's a
bit of
backquotes and 0D junk, nothing more).
Here's a sample of an amf call/response:
<TRCPacket ticket="39" connectionNumber="3" timestamp="32578"
from="CLIENT" type="HTTP">
<data length="462" encoding="ASCIIFY" encodedLength="523"
type="HTTPDATA" ><![CDATA[POST /flex/amfgateway HTTP/1.1`0D`
Accept: */*`0D`
x-flash-version: 8,5,0,246`0D`
Content-Type: application/x-amf`0D`
Content-Length: 66`0D`
Accept-Encoding: gzip, deflate`0D`
User-Agent: Mozilla/4.0 (compatible; MSIE 6.0; Windows NT 5.1; SV1)`0D`
Host: u-pc094:8080`0D`
Connection: Keep-Alive`0D`
Cache-Control: no-cache`0D`
Cookie: JSESSIONID=649C4E9985F50F69B1950968A23F904F;
JSESSIONID=649C4E9985F50F69B1950968A23F904F`0D0A0D0A00000000 000100`(samples.explorer.EmployeeManager.getList`0002`/2`000 000`
`00000001020002`PM]]></data>
</TRCPacket>
<TRCPacket ticket="40" connectionNumber="3" timestamp="32625"
from="SERVER" type="HTTP">
<data length="501" encoding="ASCIIFY" encodedLength="655"
type="HTTPDATA" ><![CDATA[HTTP/1.1 200 OK`0D`
Content-Length: 364`0D`
Date: Thu, 04 May 2006 10:53:05 GMT`0D`
Server:
Apache-Coyote/1.1`0D0A0D0A000000000001000B`/2/onResult`0004` null`FFFFFFFF0A00000002100019`samples.explorer.Employee`0005 `phone`02000C`555-219-2030`000C`_remoteClass`020019`samples. explorer.Employee`0005`email`020017`rhodgman@fictitious.com`0004`name`02000E`Ronnie
Hodgman`0006`salary`000000000000000000000009100019`samples.e xplorer.Employee`0005`phone`02000C`555-219-2012`000C`_remote Class`020019`samples.explorer.Employee`0005`email`020014`jwall@fictitious.com`0004`name`02000B`Joanne
Wall`0006`salary`0000000000000000000000` ]]></data>
</TRCPacket>
Suggestions?
Thank you for your attention.
Lorenzo
| Re: HTTP Test: error converting .rec file in .testsuite file [message #69517 is a reply to message #69497] |
Fri, 05 May 2006 11:14   |
Hi Lorenzo,
This appears to be a defect since the URL recorder/test generator should
successfully create a TPTP URL Test for any HTTP request/response. Please
open a defect with the following:
-Error log file.
-URL or application to reproduce the problem.
-Recording file.
Paul
"lorenzo benvenuti" <lorenzobenvenuti@grupposervizi.it> wrote in message
news:e3f7dh$e9o$1@utils.eclipse.org...
> Hi all,
> using TPTP
> .testsuite file.
> found that
> header, no data).
> obtain the
> based RIA
> Flex
Tomcat
> between .rec
> finally I
(Content-type:
> bit of
> Accept: */*`0D`
explorer.EmployeeManager.getList`0002`/2`000000`
> </TRCPacket>
> Server:
0000002100019`samples.explorer.Employee`0005`phone`02000C`55 5-219-2030`000C`
_remoteClass`020019`samples.explorer.Employee`0005`email`020 017`rhodgman@fic
`0005`phone`02000C`555-219-2012`000C`_remoteClass`020019`sam ples.explorer.Em
> </TRCPacket>
> Suggestions?
> Lorenzo
| Re: HTTP Test: error converting .rec file in .testsuite file [message #70461 is a reply to message #69517] |
Thu, 11 May 2006 02:16   |
Paul,
thank you for your reply.
How do I open a defect? Sorry, never done this before.
Lorenzo
Paul Slauenwhite wrote:
> Hi Lorenzo,
> -Error log file.
> -Recording file.
> Paul
>>Hi all,
>>using TPTP
>>.testsuite file.
>>found that
>>header, no data).
>>obtain the
>>based RIA
>>Flex
> Tomcat
>>between .rec
>>finally I
> (Content-type:
>>bit of
>>Accept: */*`0D`
>></TRCPacket>
>>Server:
>></TRCPacket>
>>Suggestions?
>>Regards,
>>Lorenzo
| Re: HTTP Test: error converting .rec file in .testsuite file [message #70499 is a reply to message #70461] |
Thu, 11 May 2006 08:50   |
Hi Lorenzo,
You can open a defect here:
http://www.eclipse.org/tptp/ >> Submit Enhancements & Bugs >> Report a new
bug. >> TPTP
Paul
news:e3ul5b$p08$1@utils.eclipse.org...
> Paul,
> Lorenzo
> > Hi Lorenzo,
should
Please
> > -Error log file.
> > -Recording file.
> > Thanks,
> > Paul
> >>Hi all,
> >>using TPTP
HTTP
> >>.testsuite file.
> >>found that
> >>header, no data).
> >>obtain the
> >>based RIA
> >>Flex
> > Tomcat
> >>between .rec
> >>finally I
> > (Content-type:
> >>bit of
> >>Accept: */*`0D`
> >></TRCPacket>
> >>Server:
> >></TRCPacket>
> >>Suggestions?
> >>Regards,
> >>Lorenzo
| Re: HTTP Test: error converting .rec file in .testsuite file [message #70615 is a reply to message #70499] |
Fri, 12 May 2006 09:08   |
I'm going to do it ASAP.
Lorenzo
> Hi Lorenzo,
> bug. >> TPTP
> Paul
>>Paul,
>>Thanks,
>>Lorenzo
>>>Hi Lorenzo,
> should
> Please
>>>-Error log file.
>>>-Recording file.
>>>Thanks,
>>>Paul
>>>>Hi all,
>>>>using TPTP
> HTTP
>>>>.testsuite file.
>>>>found that
>>>>header, no data).
>>>>obtain the
>>>>based RIA
>>>>Flex
>>>Tomcat
>>>>between .rec
>>>>finally I
>>>(Content-type:
>>>>bit of
>>>>Accept: */*`0D`
>>>></TRCPacket>
>>>>Server:
>>>></TRCPacket>
>>>>Suggestions?
>>>>Regards,
>>>>Lorenzo
| Re: HTTP Test: error converting .rec file in .testsuite file [message #85997 is a reply to message #70615] |
Thu, 26 October 2006 02:50   |
Originally posted by: hakan.noemail.com
Did you find out what caused this problem? This happens to me too when
running my own application who is communicating with the server using XML.
Is there any workaround or fix for this problem?
Håkan
> Lorenzo
>> Hi Lorenzo,
>> new
>> bug. >> TPTP
>> Paul
>>> Paul,
>>> Thanks,
>>> Lorenzo
>>>> Hi Lorenzo,
>> should
>> Please
>>>> -Error log file.
>>>> -Recording file.
>>>> Thanks,
>>>> Paul
>>>> message
>>>>> Hi all,
>>>>> using TPTP
>> HTTP
>>>>> .testsuite file.
>>>>> found that
>>>>> header, no data).
>>>>> obtain the
>>>>> based RIA
>>>>> of all
>>>>> Flex
>>>> Tomcat
>>>>> between .rec
>>>>> finally I
>>>> (Content-type:
>>>>> bit of
>>>>> Accept: */*`0D`
>>>>> SV1)`0D`
>>>>> </TRCPacket>
>>>>> Server:
>>>>> </TRCPacket>
>>>>> Suggestions?
>>>>> Regards,
>>>>> Lorenzo
| Re: HTTP Test: error converting .rec file in .testsuite file [message #89337 is a reply to message #70615] |
Mon, 04 December 2006 09:55   |
Lorenzo,
Did you have the chance to file a defect for this problem? If so, do
you have the defect number since I cannot find any defects in Bugzilla filed
under your email address.
Paul
news:e421m5$4p2$1@utils.eclipse.org...
> Lorenzo
>> Hi Lorenzo,
>> new
>> bug. >> TPTP
>> Paul
>>>Paul,
>>>Thanks,
>>>Lorenzo
>>>>Hi Lorenzo,
>> should
>> Please
>>>>-Error log file.
>>>>-Recording file.
>>>>Thanks,
>>>>Paul
>>>>>Hi all,
>>>>>using TPTP
>> HTTP
>>>>>.testsuite file.
>>>>>found that
>>>>>header, no data).
>>>>>obtain the
>>>>>based RIA
>>>>>all
>>>>>Flex
>>>>Tomcat
>>>>>between .rec
>>>>>finally I
>>>>(Content-type:
>>>>>bit of
>>>>>Accept: */*`0D`
>>>>></TRCPacket>
>>>>>Server:
>>>>></TRCPacket>
>>>>>Suggestions?
>>>>>Regards,
>>>>>Lorenzo
Current Time: Tue Dec 02 17:40:13 EST 2025
Powered by FUDForum. Page generated in 0.46300 seconds
