PDT dependecies [message #69479] |
Fri, 25 April 2008 18:00  |
HI I'm just trying to create my perfect PDT env, an for achieving that I
need to trim the base core eclipse system, but in order to do it I
need to know exaclty which packages does PDE require to work
EMF for example is a big framework and im pretty sure that yuy're not
using it at it's fullness .
so far I have removed
java, ant, cvs, a few emf, and others... and my eclipse just eats 6mbs
of ram without any open project now, nice huh :)
Re: PDT dependecies [message #69518 is a reply to message #69479] |
Mon, 28 April 2008 02:40   |
Originally posted by: spam.networks.fi
On Sat, 26 Apr 2008 01:00:41 +0300, Hertzel Armengol <emudojo@gmail.com>
And then you install a update which uses something new.. and all hell
breaks loose :)
jasmo
Re: PDT dependencies [message #69578 is a reply to message #69538] |
Tue, 29 April 2008 13:53   |
Originally posted by: codeslave.ca.ibm.com
If PDT is correctly depending on EMF *plugins* instead of *features*
then only the minimum required plugins and their much-smaller-containing
features will be used. This change was done for WTP's benefit last year
-- PDT ought to do the same, as it depends on WTP in turn.
I recommend opening a bug against PDT asking that they depend on the
smaller EMF features and/or just the plugins. Then your install
experience will be much smaller.
https://bugs.eclipse.org/bugs/enter_bug.cgi?product=PDT
Post this link in the bug for their reference:
http://wiki.eclipse.org/EMF/EMF_2.3/New_Features_Migration_G uide
Nick
Jacob Fogg wrote:
> Any way to package that? I am sure there are a LOT of people who would
> be interested!
>> I need to trim the base core eclipse system, but in order to do it I
Re: PDT dependencies [message #69617 is a reply to message #69578] |
Tue, 29 April 2008 14:03  |
Done
https://bugs.eclipse.org/bugs/show_bug.cgi?id=229421
hope it helps
> Cheers,
> Nick
>> would be interested!
>>> that I need to trim the base core eclipse system, but in order to do
>>> it I need to know exaclty which packages does PDE require to work
>>> 6mbs of ram without any open project now, nice huh :)
FUDForum. Page generated in 0.04157 seconds
