Home » Language IDEs » ServerTools (WTP) » Error in one class
Error in one class [message #69472] Fri, 28 January 2005 03:16 Go to next message
I'm getting a comp
Re: Error in one class [message #69610 is a reply to message #69472] Fri, 28 January 2005 09:15 Go to previous messageGo to next message
I believe this project was removed from the WTP set (as defined by the
"maps" in the org.eclipse.wtp.releng project) a while back. At least it's
not in current builds.
If it helps, attached is a zip containing a freshly generated set of full
WTP (i.e. wst & jst) project set files. It covers 4 projects sets, IBuild
(as of today) and NBuild, with and without "test" projects.
Larry
"Emerson Cargnin" <echofloripa@bol.com.br> wrote in message
news:ctcovh$9kf$1@www.eclipse.org...
> I'm getting a comp
Re: Error in one class [message #69729 is a reply to message #69610] Sat, 29 January 2005 01:18 Go to previous messageGo to next message
one should update the project set file available in developers page.
Emerson
"Larry Isaacs" <Larry.Isaacs@sas.com> escreveu na mensagem
news:ctdhej$c5b$1@www.eclipse.org...
> Cheers,
> Larry
> > I'm getting a comp
Re: Error in one class [message #69834 is a reply to message #69729] Sat, 29 January 2005 12:49 Go to previous message
I get a socket error when trying to use the nightly build with tests.
The same error than using the psf available at the site.
Emerson
"Emerson Cargnin" <echofloripa@bol.com.br> escreveu na mensagem
news:ctf6g2$5rf$1@www.eclipse.org...
> Emerson
it's
full
IBuild
> > Cheers,
> > Larry
> > > I'm getting a comp
Previous Topic:Converting a project to WTP
Next Topic:unable to open th jsp editor
Current Time: Mon Nov 17 08:49:30 EST 2025
Powered by FUDForum. Page generated in 0.03730 seconds
