Home » Language IDEs » ServerTools (WTP) » DB connect to DB2 V8 jcc driver
DB connect to DB2 V8 jcc driver [message #69427] Fri, 28 January 2005 00:01 Go to next message
Originally posted by: lushiwei.cn.ibm.com
Try to use DB2 JCC driver to connect DB2 UDB V8
JDBC Driver Class : com.ibm.db2.jcc.DB2Driver
Class location :
" D:\Eclipse\workspace\JDBC_Sample\lib\db2jcc_license_cu.jar;D :\Eclipse\workspace\JDBC_Sample\lib\db2jcc.jar "
URL: jdbc:db2://<HOSTNAME>:50000/testDB
get a error message:
Connect to DB2 UDB failed. The version of the IBM Universial JDBC Driver
in use is not licensed for connectivity to DB2 for Unix/Windows database.
But I can connect to database use a java execute class include those libs.
Re: DB connect to DB2 V8 jcc driver [message #71080 is a reply to message #69427] Wed, 02 February 2005 17:44 Go to previous messageGo to next message
Please try to use this license jar file instead.
db2jcc_license_cisuz.jar
Der Ping
> Class location :
" D:EclipseworkspaceJDBC_Samplelibdb2jcc_license_cu.jar;D:Ecli pseworkspaceJDBC_Samplelibdb2jcc.jar "
Re: DB connect to DB2 V8 jcc driver [message #71197 is a reply to message #71080] Wed, 02 February 2005 21:43 Go to previous messageGo to next message
Thank you, Ping
I can connect to my DB2 server use jcc driver after I restart a clean
eclipse enviroment(restart a new worksapce). Now I use
db2jcc_license_cu.jar or db2jcc_license_cisuz.jar can connect to my DB2
server.
Best Regard
ShiWei Lu
> Der Ping
>> Class location :
Re: DB connect to DB2 V8 jcc driver [message #72263 is a reply to message #71197] Mon, 07 February 2005 22:51 Go to previous messageGo to next message
Lushewei,
You can also use 'Other Driver' to connect to DB2, for example; DB2 APP
driver or any other third party JDBC drivers. Just make sure you have the
class name, jar file location and URL correctly configured.
Der ping
lushiwei wrote:
> Thank you, Ping
> server.
> Best Regard
> ShiWei Lu
>> Der Ping
>>> Class location :
Re: DB connect to DB2 V8 jcc driver [message #76575 is a reply to message #71080] Thu, 24 February 2005 12:56 Go to previous message
Der Ping, could you please explain what is different about the two
"license" jars in the DB2 distribution?
Ian
Previous Topic:Extending WTP Wizards in a reusable way
Next Topic:RDB Tool
Current Time: Sat May 31 09:33:16 EDT 2025
Powered by FUDForum. Page generated in 0.07982 seconds
