| Test Execution Result [message #69391] |
Thu, 04 May 2006 04:11  |
Originally posted by: bharat51.hotmail.com
I am facing a another wierd problem now.
environment:
OS: Linux
TPTP : 4.1.0
Eclipse : 3.1.1
JDK: 1.5.0_03
Project under test: org.test.ui.headless
Project that initiates the test: Test_Runner
Workspace path = /root/EclipseWorkspace
Eclipse path: /opt/eclipse
When ever I run my tests through another project via a "java program using
the automatable service framework", the results (.execution file) get
created on the root folder location instead of the workspace project path.
/<project-name>/resuts.execution.
According to the documentation the resuts (.execution file) should get
stored under the workspace/project folder but in my case it stores on the
root path. In the event that I delete the project-name from the root
folder, the execution creates a new fiolder by the name of the project in
the workspace.
If i run the testsuite using the "Run As" > "Test" , it creates the
execution file correctly under the workspace project folder.
Any ideas why this is happening?
Bharat
FUDForum. Page generated in 0.06525 seconds
