| Using SWTBot to wait for a dialog to display [message #6169] |
Fri, 05 December 2008 18:15  |
In my trials of using SWTBot I just ran into the first instance where I
need to wait for a particular dialog to appear before continuing with a
test. I searched for some examples of this but didn't find any.
What is the syntax that I should use to wait for a shell with the name
"Configuration" to appear?
Looking at an implementation of shellWithId() I assumed I should do
something similar to the following:
WaitForShell waitForShell =
waitForShell(WidgetMatcherFactory.withText("Configuration"));
bot.waitUntilWidgetAppears(waitForShell);
Without any examples readily available I wanted to verify that this is
the suggested method for waiting for a dialog with a particular title.
Some comments:
- I think what would be extremely valuable to those getting familiar
with SWTBot if some examples of how to find/wait for various SWT
elements were made available.
- providing a SWTBot.shellWithText(String title) method would be useful.
Joe
| Re: Using SWTBot to wait for a dialog to display [message #7552 is a reply to message #6184] |
Mon, 08 December 2008 12:58   |
Ketan Patel wrote:
> I am using version 2.0 and it has following method to wait for shell:
> * @return a wrapper around a @{link Shell} with the specified text.
> * @param text the text on the shell.
> public SWTBotShell shell(String text) {
> return shell(text, 0);
> * @return a wrapper around a {@link Shell} with the specified index.
> * @param index the index of the shell, in case there are multiple shells
> with the same text.
> public SWTBotShell shell(String text, int index) {
> WaitForShell waitForShell = waitForShell(withText(text));
> return waitForShell.get(index);
Thanks, I will try to use the SWTBotFactory.shell() method.
BTW, there is a difference in the APIs that you referenced versus what I
am using. I guess a difference in version 2.0 vs. version 2.0.0.1164?
I am using the latter and have the following APIs
shells with the same text.
return new SWTBotShell(shells(text).get(index));
public List<Shell> shells(String text) {
ArrayList<Shell> allShells = waitForShell.getAllShells();
return allShells;
Joe
FUDForum. Page generated in 0.04640 seconds
