Home » Eclipse Projects » DSDP - Target Management » Re: terminal view of target management
Re: terminal view of target management [message #6167] Thu, 01 March 2007 12:26
Hello Markus,
The Terminal View should be available by
Window > Show View > Other > Terminal > Terminal
If this doesn't work, please file a bug in bugzilla.
BTW, using the eclipse.dsdp.tm newsgroup for such sort of questions
would be preferred.
Martin Oberhuber
Target Management Project Lead, DSDP PMC Member
http://www.eclipse.org/dsdp/tm
Markus Brenner wrote:
> hi martin,
> i installed rse 1.01 through the eclipse update/install feature. i can
> see most panes (with the various services like ssh, ftp, local to
> select from), but i cannot find the view for the
> serial/vt102/terminal. how can
> i activate it? i searched the web/project-page for info about the
> serial terminal, but couldn't find anything ;(
> i installed rxtx 2.1.7 as stated. i'm using eclipse 3.2.2. and i can
> see the that the "tm terminal sdk" is in the product configuration
> listed (ssh and serial connector, view and widget).
> thanks,
> markus
Previous Topic:Target Management 2.0M5 is released!
Next Topic:Re: terminal view of target management
Current Time: Sun Nov 09 04:39:49 EST 2025
Powered by FUDForum. Page generated in 0.03473 seconds
