Home » Language IDEs » Java Development Tools (JDT) » I don't want tabs when copying code to the clipboard
I don't want tabs when copying code to the clipboard [message #69316] Sat, 28 June 2003 00:10 Go to next message
Originally posted by: cay_horstmann.yahoo.com
I don't want tabs when copying code to the clipboard. (When I paste into
Netscape composer, tabs are 8 spaces!)
In Preferences->Java->Appearance->Code Formatter, I un-checked "Insert
tabs for indentation, not spaces". So, why do I have tabs at all?
I sure hope I won't have to go back to Emacs just to copy and paste code
snippets into another program.
Thanks for any help!
Cay
Re: I don't want tabs when copying code to the clipboard [message #69487 is a reply to message #69316] Sat, 28 June 2003 10:50 Go to previous messageGo to next message
This option is controlling auto-format routines. For other typing, you
need to change Preferences->Java->Editor->Typing 'Insert spaces for
tabs' - at least it is called so in 3.0M1. I also had to disable
'pasting for correct indentation' - it is messing with layout in 100% cases.
Artur
Re: I don't want tabs when copying code to the clipboard [message #69507 is a reply to message #69487] Sat, 28 June 2003 11:29 Go to previous messageGo to next message
> Artur
Thank you VERY much! It works beautifully. (I had to Source->Format to get
rid of the tabs, and then copy.)
Cay
Re: I don't want tabs when copying code to the clipboard [message #73541 is a reply to message #69487] Mon, 07 July 2003 12:40 Go to previous messageGo to next message
Any idea where I would look to see how "pasting for correct indentation" is
implemented? I'd like to be able to insert formatted source code into the
existing code, but I don't know how to retrieve the current indentation
level at the cursor. I found an example using ICodeFormatter that requires
this information.
"Artur Biesiadowski" <abies@pg.gda.pl> wrote in message
news:bdk9v9$gq6$1@rogue.oti.com...
cases.
> Artur
Re: I don't want tabs when copying code to the clipboard [message #73558 is a reply to message #73541] Mon, 07 July 2003 12:46 Go to previous message
Originally posted by: tom.eicher.gmx.ch.nodomain
check JavaAutoIndentStrategy.smartIndentAfterNewLine()
-tom
"Ernest Pasour" <Ernest.Pasour@sas.com> wrote in message
news:bec7q5$v1l$1@eclipse.org...
is
requires
> this information.
into
> cases.
> > Artur
Previous Topic:how to map a Project to existing directories?
Next Topic:Use Variables when attaching javadocs to jar
Current Time: Tue Jun 03 05:36:53 EDT 2025
Powered by FUDForum. Page generated in 0.03239 seconds
