Home » Archived » XML Schema Definition (XSD) » xsd2ecore
xsd2ecore [message #69291] Sat, 19 August 2006 16:39 Go to next message
While reverse engineering a XSD to eCore I generate a .xsd2ecore file.
Having changed the mapping in the .xsd2ecore file how I can a re-run it from
inside Eclipse?
Re: xsd2ecore [message #69312 is a reply to message #69291] Sat, 19 August 2006 18:01 Go to previous messageGo to next message
--------------030902010108090407020406
Matthew,
That file is produced only to reflect what the XSDEcoreBuilder does,
i.e., the relationship between the input schema and the output Ecore.
It's not used as input to drive anything else. Short of writing a
derived XSDEcoreBuilder, the best way to affect the mapping is to use
the annotations in described in:
http://www.eclipse.org/emf/docs/overviews/XMLSchemaToEcoreMa pping.pdf
Support for quite a few new annotations was added in 2.2 and are not yet
documented.
You'll note that the XML Schema information is recorded as EAnnotations
and this annotation syntax can be used directly on any Ecore model to
affect not only how instances of that model are serialized to XML but
also to influence how that model itself is mapped to XML Schema when
exported...
> inside Eclipse?
<html>
<head>
<title></title>
</head>
Matthew,<br>
<br>
i.e., the relationship between the input schema and the output Ecore.&nbsp;
It's not used as input to drive anything else.&nbsp; Short of writing a
the annotations in described in:<br>
<blockquote><a
href=" http://www.eclipse.org/emf/docs/overviews/XMLSchemaToEcoreMa pping.pdf"> http://www.eclipse.org/emf/docs/overviews/XMLSchemaToEcoreMa pping.pdf</a><br>
</blockquote>
yet documented.<br>
exported...<br>
<br>
<br>
<blockquote cite="midec7su2$jja$1@utils.eclipse.org" type="cite">
<pre wrap="">While reverse engineering a XSD to eCore I generate a .xsd2ecore file.
inside Eclipse?
</pre>
</blockquote>
<br>
</body>
</html>
--------------030902010108090407020406--
Re: xsd2ecore [message #69329 is a reply to message #69312] Sat, 19 August 2006 18:42 Go to previous message
Ed - thanks. This is clear, quick, and I confirm it answers the question.
Re: xsd2ecore [message #598573 is a reply to message #69291] Sat, 19 August 2006 18:01 Go to previous message
Matthew,
documented.
exported...
> inside Eclipse?
<html>
<head>
<title></title>
</head>
Matthew,<br>
<br>
<blockquote><a
</blockquote>
yet documented.<br>
exported...<br>
<br>
<br>
inside Eclipse?
</pre>
</blockquote>
<br>
</body>
</html>
Re: xsd2ecore [message #598582 is a reply to message #69312] Sat, 19 August 2006 18:42 Go to previous message
Previous Topic:xsd2ecore
Next Topic:suggestion to use namespace prefix for nsPrefix in XSD2eCore mapping
Current Time: Thu Nov 20 20:28:25 EST 2025
Powered by FUDForum. Page generated in 0.04277 seconds
