Home » Archived » Service Component Architecture (SCA) Tools » Tutorial has to be changed
Tutorial has to be changed [message #6162] Mon, 16 February 2009 09:03 Go to next message
As finished modelling the Restaurant component from the tutorial I
wanted to test it. But I got an exception:
Exception in thread "main" org.osoa.sca.ServiceRuntimeException:
Reference not found for component reference: Component =
RestaurantServiceComponent Reference = menuReference
In the part of the tutorial where the references will be set, the names
are specified like (a..z)*Reference. But the annotated setters in the
implementation classes are called set(a..z)*Service. That's why the
exception is thrown. Please change the tutorial that both names match.
greets
Jan
Re: Tutorial has to be changed [message #6192 is a reply to message #6162] Mon, 16 February 2009 09:24 Go to previous messageGo to next message
> greets
> Jan
Thanks Jan. I made the modifications [0].
Stephane Drapeau
Obeo
[0]:
http://wiki.eclipse.org/STP/SCA_Component/SCA_First_Steps_Wi th_Composite_Designer#References
Re: Tutorial has to be changed [message #574571 is a reply to message #6162] Mon, 16 February 2009 09:24 Go to previous messageGo to next message
> greets
> Jan
Stephane Drapeau
Obeo
[0]:
Re: Tutorial has to be changed [message #792549 is a reply to message #574571] Tue, 07 February 2012 00:33 Go to previous messageGo to next message
Stephane,
Help documentation distributed with Eclipse is not updated with these changes!
Hope you can change them too.
Thanks.
Piram
Re: Tutorial has to be changed [message #836359 is a reply to message #792549] Wed, 04 April 2012 07:47 Go to previous message
Yes, you are right.
We need to update the samples (a little bit) and the documentation.
Previous Topic:Differences between SCA models
Next Topic:SOA application
Current Time: Fri Jul 25 14:48:26 EDT 2025
Powered by FUDForum. Page generated in 0.03183 seconds
