Home » Language IDEs » Java Development Tools (JDT) » Create a IVMInstall?
Create a IVMInstall? [message #69157] Fri, 27 June 2003 17:08 Go to next message
Originally posted by: richkulp.NOSPAM.us.ibm.com
IS there an API way of programtically adding an installed VM to the
system? I don't see a document explaining this but it looks like I would
create a VMStandIn using the IVMInstallType of interest as the ctor part
along with a new, such as the standard install type (i.e. I just want to
create a standard JRE install but not the one that JRE_LIB uses), then
use convertToRealVM() on it and that should install, no?
Thanks, Rich Kulp
Re: Create a IVMInstall? [message #69200 is a reply to message #69157] Fri, 27 June 2003 17:17 Go to previous messageGo to next message
A few corrections:
along with a name that I want for it, such as the standard install type
then set up the VMStandin to point to the desired location, and then
Thanks, Rich Kulp
Re: Create a IVMInstall? [message #73721 is a reply to message #69157] Mon, 07 July 2003 15:24 Go to previous message
Yes, using a VMStandin, and then calling convertToRealVM() will work.
Darin
"Richard L. Kulp" <richkulp@NOSPAM.us.ibm.com> wrote in message
news:bdibqs$dh3$1@rogue.oti.com...
> Thanks, Rich Kulp
Previous Topic:Launching a configuration
Next Topic:Problems with PDE
Current Time: Fri Nov 07 03:14:44 EST 2025
Powered by FUDForum. Page generated in 0.06036 seconds
