RAServer Runtime exception [message #69144] |
Mon, 01 May 2006 12:19 |
Originally posted by: jian.fang.acntv.com
When I run RAServer to profile an local application by using
-XrunpiAgent:server=controlled. During the running I got an exception
and the RAServer stops. My machine is Fedora Core 5 and Eclipse 3.2 RC1a
with Gnome.
The exception is as follows,
*** glibc detected *** RAServer: free(): invalid next size (normal):
0x09aaa6b8 ***
======= Backtrace: =========
/lib/libc.so.6[0x8aaf18]
/lib/libc.so.6(__libc_free+0x79)[0x8ae41d]
/usr/local/AgentController/lib/libhcclserc.so[0x5321f2]
/usr/local/AgentController/lib/libhcclserc.so(ra_logServiceC ommonBaseEvent__FP20hcbe_CommonBaseEvent+0xf8)[0x5322f8]
/usr/local/AgentController/lib/libhcclserc.so(ra_logServiceM essage+0x651)[0x5329dd]
RAServer[0x8056b6b]
RAServer[0x8050e18]
RAServer[0x80523f5]
/lib/libpthread.so.0[0xae13b6]
/lib/libc.so.6(__clone+0x5e)[0x90f33e]
======= Memory map: ========
00111000-00461000 r-xp 00000000 08:07 1966507
/usr/local/AgentController/lib/libxerces-c.so.26.0
00461000-00517000 rwxp 0034f000 08:07 1966507
00517000-00519000 rwxp 00517000 00:00 0
0051d000-00526000 r-xp 00000000 08:07 1965093
/usr/local/AgentController/lib/libhcclco.so
00526000-00527000 rwxp 00008000 08:07 1965093
00527000-00537000 r-xp 00000000 08:07 1966500
00537000-00539000 rwxp 0000f000 08:07 1966500
00539000-0053f000 rwxp 00539000 00:00 0
0053f000-00560000 r-xp 00000000 08:07 788754
/usr/java/jdk1.5.0_06/jre/lib/i386/libjava.so
00560000-00562000 rwxp 00020000 08:07 788754
00562000-00564000 rwxp 00562000 00:00 0
00564000-005e2000 rwxp 00564000 00:00 0
005e2000-005eb000 rwxp 005e2000 00:00 0
005eb000-00603000 rwxp 005eb000 00:00 0
00603000-00609000 r-xp 00000000 08:07 788769
/usr/java/jdk1.5.0_06/jre/lib/i386/libnio.so
00609000-0060a000 rwxp 00005000 08:07 788769
0061c000-0062d000 r-xp 00000000 08:07 1998934 /lib/libnsl-2.4.so
0062d000-0062e000 r-xp 00010000 08:07 1998934 /lib/libnsl-2.4.so
0062e000-0062f000 rwxp 00011000 08:07 1998934 /lib/libnsl-2.4.so
0062f000-00631000 rwxp 0062f000 00:00 0
00631000-00632000 rwxp 00631000 00:00 0
00632000-00634000 rwxp 00632000 00:00 0
00634000-00636000 rwxp 00634000 00:00 0
00636000-00651000 rwxp 00636000 00:00 0
00651000-00659000 rwxp 00651000 00:00 0
00659000-00671000 rwxp 00659000 00:00 0
00671000-00672000 rwxp 00671000 00:00 0
00672000-00673000 --xp 00672000 00:00 0
00673000-006f3000 rwxp 00673000 00:00 0
00707000-00711000 r-xp 00000000 08:07 1965096
/usr/local/AgentController/lib/libhcclsm.so
00711000-00713000 rwxp 00009000 08:07 1965096
00713000-00716000 --xp 00713000 00:00 0
00716000-00794000 rwxp 00716000 00:00 0
00794000-00797000 --xp 00794000 00:00 0
00797000-00815000 rwxp 00797000 00:00 0
00829000-0082a000 r-xp 00829000 00:00 0 [vdso]
0082a000-00843000 r-xp 00000000 08:07 1998918 /lib/ld-2.4.so
00843000-00844000 r-xp 00018000 08:07 1998918 /lib/ld-2.4.so
00844000-00845000 rwxp 00019000 08:07 1998918 /lib/ld-2.4.so
00847000-00973000 r-xp 00000000 08:07 1998922 /lib/libc-2.4.so
00973000-00976000 r-xp 0012b000 08:07 1998922 /lib/libc-2.4.so
00976000-00977000 rwxp 0012e000 08:07 1998922 /lib/libc-2.4.so
00977000-0097a000 rwxp 00977000 00:00 0
0097c000-0099f000 r-xp 00000000 08:07 1998923 /lib/libm-2.4.so
0099f000-009a0000 r-xp 00022000 08:07 1998923 /lib/libm-2.4.so
009a0000-009a1000 rwxp 00023000 08:07 1998923 /lib/libm-2.4.so
009a3000-009a5000 r-xp 00000000 08:07 1998924 /lib/libdl-2.4.so
009a5000-009a6000 r-xp 00001000 08:07 1998924 /lib/libdl-2.4.so
009a6000-009a7000 rwxp 00002000 08:07 1998924 /lib/libdl-2.4.so
009b8000-009cb000 r-xp 00000000 08:07 788774
/usr/java/jdk1.5.0_06/jre/lib/i386/libzip.so
009cb000-009cd000 rwxp 00012000 08:07 788774
009cd000-009d0000 --xp 009cd000 00:00 0
009d0000-00a4e000 rwxp 009d0000 00:00 0
00a4e000-00a51000 --xp 00a4e000 00:00 0
00a51000-00acf000 rwxp 00a51000 00:00 0
00adc000-00aec000 r-xp 00000000 08:07 1998926 /lib/libpthread-2.4.so
00aec000-00aed000 r-xp 0000f000 08:07 1998926 /lib/libpthread-2.4.so
00aed000-00aee000 rwxp 00010000 08:07 1998926 /lib/libpthread-2.4.so
00aee000-00af0000 rwxp 00aee000 00:00 0
00b5c000-00b7b000 r-xp 00000000 08:07 1966511
/usr/local/AgentController/lib/libcbe.so
00b7b000-00b7c000 rwxp 0001e000 08:07 1966511
00b7c000-00b7f000 --xp 00b7c000 00:00 0
00b7f000-00bfd000 rwxp 00b7f000 00:00 0
00c3e000-00c49000 r-xp 00000000 08:07 1998927
/lib/libgcc_s-4.1.0-20060304.so.1
00c49000-00c4a000 rwxp 0000a000 08:07 1998927
00c53000-00c54000 rwxp 00c53000 00:00 0
00c54000-00c70000 rwxp 00c54000 00:00 0
00ce6000-00cef000 r-xp 00000000 08:07 1994985 /lib/libnss_files-2.4.so
00cef000-00cf0000 r-xp 00008000 08:07 1994985 /lib/libnss_files-2.4.so
00cf0000-00cf1000 rwxp 00009000 08:07 1994985 /lib/libnss_files-2.4.so
00d5c000-00d67000 r-xp 00000000 08:07 788773
/usr/java/jdk1.5.0_06/jre/lib/i386/libverify.so
00d67000-00d68000 rwxp 0000b000 08:07 788773
00dae000-00db4000 r-xp 00000000 08:07 788778
/usr/java/jdk1.5.0_06/jre/lib/i386/native_threads/libhpi.so
00db4000-00db5000 rwxp 00006000 08:07 788778
00db5000-00db8000 --xp 00db5000 00:00 0
00db8000-00e36000 rwxp 00db8000 00:00 0
00e4a000-00e4d000 r-xp 00000000 08:07 1965095
/usr/local/AgentController/lib/libhccls.so
00e4d000-00e4e000 rwxp 00002000 08:07 1965095
00e4e000-00e51000 --xp 00e4e000 00:00 0
00e51000-00ecf000 rwxp 00e51000 00:00 0
00f3e000-00f42000 r-xp 00000000 08:07 1966499
/usr/local/AgentController/lib/libhcclsert.so
00f42000-00f43000 rwxp 00003000 08:07 1966499
00f7e000-00f92000 r-xp 00000000 08:07 788768
/usr/java/jdk1.5.0_06/jre/lib/i386/libnet.so
00f92000-00f93000 rwxp 00013000 08:07 788768
00fa6000-00fde000 r-xp 00000000 08:07 3651684
/usr/lib/libstdc++-3-libc6.2-2-2.10.0.so
00fde000-00fe7000 rwxp 00037000 08:07 3651684
00fe7000-00fe9000 rwxp 00fe7000 00:00 0
00fe9000-01536000 r-xp 00000000 08:07 788782
/usr/java/jdk1.5.0_06/jre/lib/i386/server/libjvm.so
01536000-01598000 rwxp 0054d000 08:07 788782
01598000-019af000 rwxp 01598000 00:00 0
019af000-019ff000 rwxp 019af000 00:00 0
019ff000-039af000 rwxp 019ff000 00:00 0
039af000-039b0000 --xp 039af000 00:00 0
039b0000-043b0000 rwxp 039b0000 00:00 0
043b0000-043b3000 --xp 043b0000 00:00 0
043b3000-04431000 rwxp 043b3000 00:00 0
04a1d000-04a1e000 --xp 04a1d000 00:00 0
04a1e000-04a9e000 rwxp 04a1e000 00:00 0
04a9e000-04aa1000 rwxp 04a9e000 00:00 0
04aa1000-0549f000 rwxp 04aa1000 00:00 0
059cb000-059d0000 r-xp 00000000 08:07 1998935 /lib/libcrypt-2.4.so
059d0000-059d1000 r-xp 00004000 08:07 1998935 /lib/libcrypt-2.4.so
059d1000-059d2000 rwxp 00005000 08:07 1998935 /lib/libcrypt-2.4.so
059d2000-059f9000 rwxp 059d2000 00:00 0
059f9000-059fa000 --xp 059f9000 00:00 0
059fa000-063fa000 rwxp 059fa000 00:00 0
063fa000-063fb000 --xp 063fa000 00:00 0
063fb000-06dfb000 rwxp 063fb000 00:00 0
06dfb000-06dfc000 --xp 06dfb000 00:00 0
06dfc000-077fc000 rwxp 06dfc000 00:00 0
08048000-0805c000 r-xp 00000000 08:07 2060624
/usr/local/AgentController/bin/RAServer
0805c000-0805d000 rwxp 00013000 08:07 2060624
0805d000-0805e000 --xp 0805d000 00:00 0
0805e000-08a5e000 rwxp 0805e000 00:00 0
0986f000-09bff000 rwxp 0986f000 00:00 0 [heap]
ac600000-ac621000 rwxp ac600000 00:00 0
ac621000-ac700000 --xp ac621000 00:00 0
ac78f000-ac891000 rwxs 00000000 00:07 1146908 /SYSV6d07f52d (deleted)
ac891000-ac8c5000 r-xs 00000000 08:07 2061002
/usr/local/AgentController/plugins/org.eclipse.tptp.platform .collection.framework_4.1.100.v200604131758/hcframe.jar
ac8c5000-ac8da000 r-xs 00000000 08:07 2060648
/usr/local/AgentController/plugins/org.eclipse.equinox.commo n_3.2.0.v20060329.jar
ac8da000-ac9ab000 r-xs 00000000 08:07 2061009
/usr/local/AgentController/plugins/org.eclipse.osgi_3.2.0.v2 0060328.jar
ac9ab000-ac9c0000 r-xs 00000000 08:07 2061011
/usr/local/AgentController/plugins/org.eclipse.core.runtime_ 3.2.0.v20060327-1200.jar
ac9c0000-aca33000 r-xs 00000000 08:07 2060807
/usr/local/AgentController/plugins/org.eclipse.hyades.execut ion_4.2.0.v200604131758/hexl.jar
aca33000-aca65000 r-xs 00000000 08:07 2060806
/usr/local/AgentController/plugins/org.eclipse.hyades.execut ion_4.2.0.v200604131758/hexcore.jar
aca65000-aca95000 r-xs 00000000 08:07 981927
/usr/local/ant-contrib/lib/ant-contrib.jar
aca95000-acab4000 r-xs 00000000 08:07 1083862
/usr/local/apache-ant-1.6.5/lib/xml-apis.jar
acab4000-acbab000 r-xs 00000000 08:07 1083861
/usr/local/apache-ant-1.6.5/lib/xercesImpl.jar
acbab000-acbac000 r-xs 00000000 08:07 1083859
/usr/local/apache-ant-1.6.5/lib/ant-xslp.jar
acbac000-acbae000 r-xs 00000000 08:07 1083858
/usr/local/apache-ant-1.6.5/lib/ant-xalan1.jar
acbae000-acbbb000 r-xs 00000000 08:07 1083856
/usr/local/apache-ant-1.6.5/lib/ant-vaj.jar
acbbb000-acbcc000 r-xs 00000000 08:07 1083855
/usr/local/apache-ant-1.6.5/lib/ant-trax.jar
acbcc000-acbce000 r-xs 00000000 08:07 1083854
/usr/local/apache-ant-1.6.5/lib/ant-swing.jar
acbce000-acbcf000 r-xs 00000000 08:07 1083853
/usr/local/apache-ant-1.6.5/lib/ant-stylebook.jar
acbcf000-acbd8000 r-xs 00000000 08:07 1083852
/usr/local/apache-ant-1.6.5/lib/ant-starteam.jar
acbd8000-acc3f000 r-xs 00000000 08:07 1083851
/usr/local/apache-ant-1.6.5/lib/ant-nodeps.jar
acc3f000-acc42000 r-xs 00000000 08:07 1083850
/usr/local/apache-ant-1.6.5/lib/ant-netrexx.jar
acc42000-acc55000 r-xs 00000000 08:07 1083848
/usr/local/apache-ant-1.6.5/lib/ant-junit.jar
acc55000-acc5b000 r-xs 00000000 08:07 1083847
/usr/local/apache-ant-1.6.5/lib/ant-jsch.jar
acc5b000-acc5d000 r-xs 00000000 08:07 1083846
/usr/local/apache-ant-1.6.5/lib/ant-jmf.jar
acc5d000-acc5f000 r-xs 00000000 08:07 1083845
/usr/local/apache-ant-1.6.5/lib/ant-jdepend.jar
acc5f000-acc61000 r-xs 00000000 08:07 1083844
/usr/local/apache-ant-1.6.5/lib/ant-javamail.jar
acc61000-acd5e000 r-xs 00000000 08:07 1083860
/usr/local/apache-ant-1.6.5/lib/ant.jar
acd5e000-acd64000 r-xs 00000000 08:07 1083843
/usr/local/apache-ant-1.6.5/lib/ant-jai.jar
acd64000-acd67000 r-xs 00000000 08:07 1083842
/usr/local/apache-ant-1.6.5/lib/ant-icontract.jar
acd67000-acd70000 r-xs 00000000 08:07 1083841
/usr/local/apache-ant-1.6.5/lib/ant-commons-net.jar
acd70000-acd71000 r-xs 00000000 08:07 1083840
/usr/local/apache-ant-1.6.5/lib/ant-commons-logging.jar
acd71000-acd72000 r-xs 00000000 08:07 1083839
/usr/local/apache-ant-1.6.5/lib/ant-apache-resolver.jar
acd72000-acd73000 r-xs 00000000 08:07 1083838
/usr/local/apache-ant-1.6.5/lib/ant-apache-regexp.jar
acd73000-acd7f000 r-xs 00000000 08:07 1083837
/usr/local/apache-ant-1.6.5/lib/ant-apache-oro.jar
acd7f000-acd80000 r-xs 00000000 08:07 1083836
/usr/local/apache-ant-1.6.5/lib/ant-apache-log4j.jar
acd80000-acd84000 r-xs 00000000 08:07 1083835
/usr/local/apache-ant-1.6.5/lib/ant-apache-bsf.jar
acd84000-acd87000 r-xs 00000000 08:07 1083834
/usr/local/apache-ant-1.6.5/lib/ant-apache-bcel.jar
acd87000-acd89000 r-xs 00000000 08:07 1083833
/usr/local/apache-ant-1.6.5/lib/ant-antlr.jar
acd89000-ace4d000 r-xs 00000000 08:07 788684
/usr/java/jdk1.5.0_06/jre/lib/ext/localedata.jar
ace4d000-ace4f000 r-xs 00000000 08:07 788695
/usr/java/jdk1.5.0_06/jre/lib/ext/dnsns.jar
ace4f000-ace7a000 r-xs 00000000 08:07 788698
/usr/java/jdk1.5.0_06/jre/lib/ext/sunpkcs11.jar
ace7a000-acea0000 r-xs 00000000 08:07 788697
/usr/java/jdk1.5.0_06/jre/lib/ext/sunjce_provider.jar
acea0000-ad0a0000 r-xp 00000000 08:07 3635539 /usr/lib/locale/locale-archive
ad0a0000-ad140000 rwxp ad0a0000 00:00 0
ad140000-ad7b0000 rwxp ad140000 00:00 0
ad7b0000-ad910000 rwxp ad7b0000 00:00 0
ad910000-b10a0000 rwxp ad910000 00:00 0
b10a0000-b20a0000 rwxp b10a0000 00:00 0
b20a0000-b50a0000 rwxp b20a0000 00:00 0
b50a9000-b58e4000 r--s 00000000 08:07 788819
/usr/java/jdk1.5.0_06/jre/lib/charsets.jar
b58e4000-b58f8000 r--s 00000000 08:07 788818
/usr/java/jdk1.5.0_06/jre/lib/jce.jar
b58f8000-b597d000 r--s 00000000 08:07 788877
/usr/java/jdk1.5.0_06/jre/lib/jsse.jar
b597d000-b59e6000 rw-p b597d000 00:00 0
b59e6000-b7fce000 r--s 00000000 08:07 789326
/usr/java/jdk1.5.0_06/jre/lib/rt.jar
b7fce000-b7fd2000 rw-p b7fce000 00:00 0
b7fdd000-b7fe4000 r--s 00000000 08:07 3635798
/usr/lib/gconv/gconv-modules.cache
b7fe4000-b7fec000 rw-s 00000000 08:07 1504536 /tmp/hsperfdata_jfang/3478
b7fec000-b7fed000 rwxp b7fec000 00:00 0
b7fed000-b7fee000 r--p b7fed000 00:00 0
b7fee000-b7fef000 rw-p b7fee000 00:00 0
bfdee000-bfdf1000 ---p bfdee000 00:00 0
bfdf1000-bffee000 rw-p bfdf1000 00:00 0 [stack]
Any idea of what is wrong?
Thanks in advance,
Jian
FUDForum. Page generated in 0.03228 seconds
