Replicating the functionality of Product Export Wizard from Headless Build [message #69139] |
Mon, 27 July 2009 12:30  |
Originally posted by: tfrangoullides.model-driven.co.uk
I've been trying to get a headless buuld for an RCP app working and while I
can automate the build I am not getting all the functionality provided by
the export wizard. I would be very grateful if someone could just cofirm if
all the functionality is supported in the scripts for a headless build. For
example I am having trouble including native launchers with custom names and
including the jre.
Many Thanks,
Tas
Re: Replicating the functionality of Product Export Wizard from Headless Build [message #344585 is a reply to message #69163] |
Tue, 28 July 2009 02:45   |
Hi Andrew,
I was using productBuild.xml but not using the delta-pack as my target. I'll
try that!
Also good to know there is a means to get the JRE included. I'll give it go.
Thanks for your help,
Tas
"Andrew Niefer" <aniefer@ca.ibm.com> wrote in message
news:h4kp1g$83s$1@build.eclipse.org...
> Yes, in general you can do more in the headless build than you can do in
> export :)
> You want to run a build using the same .product file, and you can run
> productBuild.xml instead of the build.xml.
> For the launchers, you need to get the delta pack
> http://download.eclipse.org/eclipse/downloads/drops/R-3.5-20 0906111540/download.php?dropFile=eclipse-3.5-delta-pack.zip
> This contains the launchers and platform specific fragments for all
> platforms.
> The JRE is perhaps the one thing that isn't directly supported. You will
> instead need to set up a feature that contributes "root files".
> See
> http://help.eclipse.org/galileo/index.jsp?topic=/org.eclipse .pde.doc.user/tasks/pde_rootfiles.htm
> This is what the UI is doing automatically for you when you export with a
> JRE. (See in particular the root.folder.<subfolder> properties on that
> page).
> There is a section at the bottom of that help page on adding root files to
> product builds. Though, if you are building for p2 using the new
> "p2.gathering=true", there is a bug here
> https://bugs.eclipse.org/bugs/show_bug.cgi?id=277824
> -Andrew
> Tas Frangoullides wrote:
>> I can automate the build I am not getting all the functionality provided
>> by the export wizard. I would be very grateful if someone could just
>> cofirm if all the functionality is supported in the scripts for a
>> headless build. For example I am having trouble including native
>> launchers with custom names and including the jre.
>> Many Thanks,
>> Tas
Re: Replicating the functionality of Product Export Wizard from Headless Build [message #344811 is a reply to message #69185] |
Tue, 28 July 2009 02:50  |
Hi Chris,
Thanks for such a great response to my question.
Chances are that the bug about deltapack is the cause. As for the JRE using
rootfiles seems very workable until Eclipse 3.6
I will try these out and see how I get on.
Tas
"Chris Aniszczyk" <zx@eclipsesource.com> wrote in message
news:h4kp6s$966$1@build.eclipse.org...
> The native launchers should work. Are you bit by this bug?
> 281224: [product] not added to feature based product without deltapack
> https://bugs.eclipse.org/bugs/show_bug.cgi?id=281224
> For the JRE, this is a known limitation. It's recommended that you use
> rootfiles to accomplish this task so that in UI and headless things work
> the same.
> http://wiki.eclipse.org/PDE/FAQ#Why_doesn.27t_my_JRE_get_inc luded_in_a_headless_build.3F
> The main reason is that PDE Build isn't aware of where the JREs are... it
> knows where class libraries are but not the actual VM. We hope to address
> this disparity in Eclipse 3.6.
> Cheers,
> Chris Aniszczyk | EclipseSource Austin | +1 860 839 2465
> http://twitter.com/eclipsesource | http://twitter.com/caniszczyk
Re: Replicating the functionality of Product Export Wizard from Headless Build [message #599955 is a reply to message #69163] |
Hi Andrew,
try that!
Tas
> export :)
> platforms.
> See
> page).
> -Andrew
>> Many Thanks,
>> Tas
FUDForum. Page generated in 0.05081 seconds
