External Ant and required jars [message #69052] |
Fri, 27 June 2003 13:52  |
Originally posted by: agooch.adelphia.net
I have the following problem. From the command line I can execute my Ant
build file. It requires an obfuscator, retroguard.jar, which is found when
I build from the command line. When I build from Eclipse the RetroGuard
class is not found. I configured Eclipse to not use global classpath as
specifed in the Ant runtime prefs, and set ANT_HOME to point to my modified
apache-ant-1.5.3 install (removed xercesImpl.jar). The retroguard.jar shows
up in the Ant runtime classpath, but does not seem to be applied. Any
ideas?
thanks in advance...
-allen
Re: External Ant and required jars [message #72491 is a reply to message #72473] |
Thu, 03 July 2003 14:39  |
Originally posted by: ehansen.convergentnet.com
Good to know. Removing that file fixed my problem.
"Darin Swanson" <Darin_Swanson@us.ibm.com> wrote in message
news:be1rs8$78r$1@rogue.oti.com...
> Because Eclipse "forces" the user to use the Xerces provide in the Xerces
> plugin.
> See https://bugs.eclipse.org/bugs/show_bug.cgi?id=36643
> Darins
> "Erik Hansen" <ehansen@convergentnet.com> wrote in message
> news:be1on6$3uc$1@rogue.oti.com...
> > Why do you have to remove xercesImpl? I am getting error messages
related
> > to that when I set ANT_HOME instead of using the Ant that is with
Eclipse.
> > "Allen Gooch" <agooch@adelphia.net> wrote in message
> > news:bdi07t$431$1@rogue.oti.com...
Ant
> > when
RetroGuard
as
> > modified
> > shows
> > > ideas?
> > > -allen
FUDForum. Page generated in 0.05262 seconds
