How to run ATL debug in Eclipse [message #6131] |
Tue, 09 January 2007 04:10  |
Originally posted by: dorazio.nicola.yahoo.it
Hi all,
I write here to ask how to run ATL debug in eclipse 3.1.1
Best regard
Nicola D'Orazio
Re: [ATL] How to run ATL debug in Eclipse [message #6250 is a reply to message #6205] |
Wed, 10 January 2007 09:37  |
Originally posted by: Hugo.Bruneliere.univ-nantes.fr
Nicola D'Orazio a écrit :
> Hugo Bruneliere ha scritto:
>> Hi Nicola,
>> You just have to run your ATL transformation launch configuration in
>> the "Debug" mode (instead of launching it in the normal "Run" mode).
>> If it does not switch automatically to the Debug perspective, you have
>> to do it manually. Then you can debug your ATL transformation.
>> Best regards,
>> Hugo
>>> Hi all,
>>> Best regard
>>> Nicola D'Orazio
> For what elements can I put the breakpoint? if I put it on a rule the
> console say to me:
> java.net.SocketException: Software caused connection abort: socket write
> error
> at java.net.SocketOutputStream.socketWrite0(Native Method)
> at java.net.SocketOutputStream.socketWrite(Unknown Source)
> at java.net.SocketOutputStream.write(Unknown Source)
> at java.io.BufferedOutputStream.flushBuffer(Unknown Source)
> at java.io.BufferedOutputStream.flush(Unknown Source)
> at java.io.DataOutputStream.flush(Unknown Source)
> at
> org.atl.engine.vm.adwp.ADWPDebugger.realSendCommand(ADWPDebu gger.java:34)
> at
> org.atl.engine.vm.adwp.ADWPDebugger.sendCommand(ADWPDebugger .java:23)
> at
> org.atl.eclipse.adt.debug.core.AtlDebugTarget.breakpointAdde d(AtlDebugTarget.java:263)
> at
> etc......................................................... ...
Hi Nicola,
Have you checked out the ATL debugging plugin as indicated in section
3.2.2 of the ATL Installation Guide?
See http://www.eclipse.org/gmt/atl/doc/ for getting the document.
Hugo
Hugo Bruneliere - R&D Engineer
ATLAS Group (INRIA & LINA) - University of Nantes
2, rue de la Houssiniere
44322 Nantes Cedex 3 - France
office +33 2 51 12 58 10 /\ cell.+33 6 07 42 45 30
EMail: Hugo.Bruneliere@univ-nantes.fr
http://www.sciences.univ-nantes.fr/lina/atl/
FUDForum. Page generated in 0.03143 seconds
