Home » Eclipse Projects » Technology Project and PMC » Cannot build Eclipse-sourceBuild
Cannot build Eclipse-sourceBuild [message #69030] Tue, 27 September 2005 06:35
Hi,All
I have a question on building eclipse source code
I do all the things following the instruction,but still "BUILD FAILED"
I've installed ANT 1.6.4
set path to ANTHOME/bin
set classpath to ant.jar and xercesImpl.jar
set path to info-zip
But when I build source, the error is:
assemble.org.eclipse.sdk.win32.win32.x86.xml:609
Execute failed: java.io.IOException: CreateProcess: zip -r -q -qq ......
It seeems that the problem is related to "zip" setting.But I'm really
confused!
Can you suggest me?
Thank you!
Previous Topic:How to control cut-off text in tabs title
Next Topic:Cannot build Eclipse-sourceBuild
Current Time: Mon Nov 17 18:22:18 EST 2025
Powered by FUDForum. Page generated in 0.04982 seconds
