Home » Archived » BIRT » Small bug: BIRT1_0_1_20050811_PATCH (Branch): When you click "Run report" button on the re
Small bug: BIRT1_0_1_20050811_PATCH (Branch): When you click "Run report" button on the re [message #69018] Mon, 22 August 2005 18:49 Go to next message
I have Windows XP desktop for development and Linux Redhat Server for
production.
I set up [BIRT_VIEWER_REPORT_ROOT] servlet parameter with '/'
separators. There was no problem the viewer'd found the report file and
previewed the report. When I changed the parameter and clicked "Run
report" button I got the error.
I guess the problem is in
org.eclipse.birt.report.viewer.utilities.ParameterAccessor.i sRelativePath
function. It considers that '/' separator can be used only under Unix
machine.
Thank you for the great product.
Sincerely,
Igor Katrayev, Data Systems Manager
North Pacific Research Board
1007 West Third Avenue, Suite 100
Anchorage, AK 99501
Phone: 907-644-6700
Fax: 907-644-6780
Re: Small bug: BIRT1_0_1_20050811_PATCH (Branch): When you click "Run report" button on th [message #69040 is a reply to message #69018] Mon, 22 August 2005 19:05 Go to previous messageGo to next message
Igor
Did you post this to bugzilla?
Jason Weathersby
BIRT PMC
"Igor Katrayev" <igor.katrayev@nprb.org> wrote in message
news:dedkqj$96a$1@news.eclipse.org...
> Hello,
> production.
> I set up [BIRT_VIEWER_REPORT_ROOT] servlet parameter with '/' separators.
> There was no problem the viewer'd found the report file and previewed the
> report. When I changed the parameter and clicked "Run report" button I got
> the error.
> machine.
> Sincerely,
> Anchorage, AK 99501
> Phone: 907-644-6700
> Fax: 907-644-6780
Re: Small bug: BIRT1_0_1_20050811_PATCH (Branch): When you click "Run report" button on th [message #69062 is a reply to message #69040] Mon, 22 August 2005 20:24 Go to previous messageGo to next message
No. I don't know how yet.
Jason Weathersby wrote:
> Igor
> Thanks
> Jason Weathersby
> BIRT PMC
Re: Small bug: BIRT1_0_1_20050811_PATCH (Branch): When you click "Run report" button on th [message #69166 is a reply to message #69062] Tue, 23 August 2005 10:28 Go to previous messageGo to next message
Igor
Use this link to create a Bugzilla account and log bugs.
http://www.eclipse.org/birt/frameizer.php?page=https://bugs. eclipse.org/bugs/
Thanks for your help
Jason Weathersby
BIRT PMC
news:dedqbu$ef5$1@news.eclipse.org...
>> Igor
>> Thanks
>> Jason Weathersby
>> BIRT PMC
Re: Small bug: BIRT1_0_1_20050811_PATCH (Branch): When you click "Run report" button on th [message #69207 is a reply to message #69166] Tue, 23 August 2005 11:33 Go to previous messageGo to next message
Bugzilla Bug 107740 created.
Igor.
> Igor
> Jason Weathersby
> BIRT PMC
>>>Igor
>>>Thanks
>>>Jason Weathersby
>>>BIRT PMC
Re: Small bug: BIRT1_0_1_20050811_PATCH (Branch): When you click "Run report" button on th [message #69246 is a reply to message #69207] Tue, 23 August 2005 12:58 Go to previous messageGo to next message
Thank you.
news:deffjq$hmp$1@news.eclipse.org...
> Igor.
>> Igor
>> Jason Weathersby
>> BIRT PMC
>>>>Igor
>>>>Thanks
>>>>Jason Weathersby
>>>>BIRT PMC
Re: Small bug: BIRT1_0_1_20050811_PATCH (Branch): When you click "Run report" button on th [message #69636 is a reply to message #69062] Thu, 25 August 2005 10:46 Go to previous message
It's pretty simple. Just go here: https://bugs.eclipse.org/bugs/
From that page you can both create a Bugzilla account and report a bug.
>> Igor
>> Thanks
>> Jason Weathersby
>> BIRT PMC
Previous Topic:problem with API
Next Topic:eXXX methods
Current Time: Tue Oct 28 20:15:17 EDT 2025
Powered by FUDForum. Page generated in 0.26710 seconds
