Home » Archived » Test and Performance Tools Platform (TPTP) » Testing webapplications with sessionids
Testing webapplications with sessionids [message #69015] Fri, 28 April 2006 07:46 Go to next message
we are trying to use tptp for performance tests of our web application.
I can record the application and generate the sources for a junit test.
We are using a sessionid for authentification, which is send with each
http-request.
When playing back the recorded http requests, I need to retrieve the
sessionid from the HttpResponse after the login-request and to replace the
recorded sessionid of further request with the actual one.
My idee was to modifiy the generated java sources, but I did not find any
way to retrieve the sessionid from the http-response.
The following code is generated by tptp:
HttpResponse response = m_httpExecutor[nUser].execute(request);
But it is impossible to get the whole http response form the response
object.
If I set a breakpoint I can see my sessionid in the chararray backing
"response.contentType", but it is not accessible in the java code.
Does anyone have an idee how to solve this problem, or where to dig for
further informations?
Ingo
Re: Testing webapplications with sessionids [message #69122 is a reply to message #69015] Mon, 01 May 2006 12:06 Go to previous messageGo to next message
Hi Ingo,
There are defects here:
1) The executeRequest(HttpRequest) method in the generated JUnit test class
for a TPTP URL test does not return the HTTP response.
2) The org.eclipse.hyades.test.http.runner.HttpResponse class does not
expose the complete HTTP response. For example, session ID.
3) Document the org.eclipse.hyades.test.http.runner classes (e.g. JavaDoc
comments).
Can you open TPTP defects for these issues (Test.Execution.URLRunner
component)?
Paul
"Ingo Weichsel" <Ingo.Weichsel@AtosOrigin.com> wrote in message
news:0f8f10dc59e643a1b422b63a34b5f159$1@www.eclipse.org...
> Hello,
> http-request.
> object.
> Ingo
Re: Testing webapplications with sessionids [message #69248 is a reply to message #69122] Mon, 01 May 2006 13:42 Go to previous messageGo to next message
Also,
4) The org.eclipse.hyades.test.http.runner.HttpRequest class does not
provide a setter for the session ID.
Paul
"Paul Slauenwhite" <paules@ca.ibm.com> wrote in message
news:e35bme$sn8$1@utils.eclipse.org...
> Hi Ingo,
class
> comments).
> component)?
> Paul
> > Hello,
> > http-request.
the
any
> > object.
> > Thanks,
> > Ingo
Re: Testing webapplications with sessionids [message #69328 is a reply to message #69248] Tue, 02 May 2006 11:17 Go to previous message
I submitted the four defects as requested.
Ingo
Paul Slauenwhite wrote:
> Also,
https://bugs.eclipse.org/bugs/show_bug.cgi?id=139709
Since the formular name for the session id is framework dependent, a
method to
define the name of the session id should be provided as well.
In our framework we send http-get-requests which are essentially set by:
request.setAbsolutePath("/~webtest1/cgi-bin/data.cgi?applId=myServer "
+ "&session=652213570&command=welcome&locale=de");
My first idea was to patch the generated sources by modifiying those
requests.
A generic way to do this or a way to configere the project to let the src
generator do this would be nice, but I do not really see a generic way to
do so...
> Paul
>> Hi Ingo,
> class
https://bugs.eclipse.org/bugs/show_bug.cgi?id=139696
https://bugs.eclipse.org/bugs/show_bug.cgi?id=139699
>> comments).
https://bugs.eclipse.org/bugs/show_bug.cgi?id=139701
>> component)?
>> Paul
>> > Hello,
>> > http-request.
> the
> any
>> > object.
>> > Thanks,
>> > Ingo
Previous Topic:Remote testing externally built code (native and java)
Next Topic:"No data is available for display" message
Current Time: Sun Jun 01 15:33:00 EDT 2025
Powered by FUDForum. Page generated in 0.04375 seconds
