| Re: [API Tools] API Tools for plain Java (not OSGi Bundles) [message #69034 is a reply to message #69013] |
Fri, 24 July 2009 10:33  |
Jan Lohre wrote:
> we have a build system (proprietary) with it's own component model. So
> what I would really like to see would be a way to plug in a custom
> IApiComponent implementation. But that goes (far?) beyond the scope of
> the existing bug report
Wow, that's interesting! Most people generally use Maven or OSGi (PDE)
I could understand the desire to create something new though ;)
> Should I still comment on 255068 or should I maybe raise a separate
> enhancement request (although then both should get some kind of link)
I think you should comment on that bug and point to the newly created
enhancement request. Patches make everything go faster too ;)
Chris Aniszczyk | EclipseSource Austin | +1 860 839 2465
http://twitter.com/eclipsesource | http://twitter.com/caniszczyk
| Re: [API Tools] API Tools for plain Java (not OSGi Bundles) [message #599874 is a reply to message #68929] |
Thu, 23 July 2009 18:24  |
Jan Lohre wrote:
> we are starting to use the API tool for our internal processes.
> Currently we have written applications to create a baseline for a simple
> jar file and to compare a jar file with such a baseline.
> In the long run we would like to support the developer in his regular
> development environment (aka Eclipse). So I would like to ask for the
> plans for 3.6
> I have seen http://wiki.eclipse.org/PDE/Plan/3.6#API_Tools and
> 255068: Check API compatibility in Java projects with PDE API Tools
> https://bugs.eclipse.org/bugs/show_bug.cgi?id=255068
> So it seems you are aware of the topic but have no concrete plans ;-)
It's still early in the planning cycle. The best bet is to stay on the bug:
I would also make known any requirement on the bug too.
The big problem with normal Java projects is that they have no way to
encode visibility like we have with OSGi artifacts. In the OSGi
MANIFEST.MF, you can specify what is visible via Export-Package and also
assign version numbers. How do you do something like that in normal Java
projects?
As a workaround, you can convert your Java projects to plug-in
projects... they should still work depending on your setup.
| Re: [API Tools] API Tools for plain Java (not OSGi Bundles) [message #599880 is a reply to message #68993] |
Fri, 24 July 2009 05:01  |
Chris Aniszczyk schrieb:
> Jan Lohre wrote:
>> simple jar file and to compare a jar file with such a baseline.
>> plans for 3.6
> projects?
> Cheers,
Hi Chris,
the existing bug report.
Kind regards,
Jan
| Re: [API Tools] API Tools for plain Java (not OSGi Bundles) [message #599883 is a reply to message #69013] |
FUDForum. Page generated in 0.29718 seconds
