Home » Archived » Service Component Architecture (SCA) Tools » Drag/Drop of interfaces/classes to a Service
Drag/Drop of interfaces/classes to a Service [message #6117] Mon, 16 February 2009 07:59 Go to next message
Today I tried the Restaurant-tutorial. There is written that one can
drag & drop interface files on the services and implementation files on
the components. But unfortunately it isn't possible :( It's a little bit
annoying that you have to fill in the classes and interface manually
without code completion. I installed the SCA Tools from this updatesite:
http://download.eclipse.org/stp/sca/last. The SCA Composite Editor and
and STP plugins were installed as Stephane described here:
news://news.eclipse.org:119/gll6ub$55v$1@build.eclipse.org.
So I expected to have the latest versions, isn't it? Any idea?
Re: Drag/Drop of interfaces/classes to a Service [message #6132 is a reply to message #6117] Mon, 16 February 2009 08:31 Go to previous messageGo to next message
Hi Jan,
I just tried with the last version ([0]) and I found a regression.
The D'n'D of an interface or a class from the package explorer view to
the designer raises an exception.
However, you can D'n'D interfaces or classes from the navigator view to
the designer... Apologies.
Can you open a bug in the Eclipse bugzilla ?
Stephane Drapeau
Obeo
[0]: http://download.eclipse.org/stp/updates/galileo/site.xml
Re: Drag/Drop of interfaces/classes to a Service [message #6147 is a reply to message #6132] Mon, 16 February 2009 08:56 Go to previous messageGo to next message
done
Re: Drag/Drop of interfaces/classes to a Service [message #6178 is a reply to message #6147] Mon, 16 February 2009 09:24 Go to previous message
> done
Thanks.
I updated the download section of the wiki with our last update site (M5).
Stephane Drapeau
Obeo
Re: Drag/Drop of interfaces/classes to a Service [message #574492 is a reply to message #6117] Mon, 16 February 2009 08:31 Go to previous message
> http://download.eclipse.org/stp/sca/last The SCA Composite Editor and
Hi Jan,
Stephane Drapeau
Obeo
Re: Drag/Drop of interfaces/classes to a Service [message #574511 is a reply to message #6132] Mon, 16 February 2009 08:56 Go to previous message
done
Re: Drag/Drop of interfaces/classes to a Service [message #574554 is a reply to message #6147] Mon, 16 February 2009 09:24 Go to previous message
> done
Thanks.
Stephane Drapeau
Obeo
Previous Topic:Tutorial has to be changed
Next Topic:SCA Meta-model & Designer extensibility
Current Time: Fri Nov 07 09:52:51 EST 2025
Powered by FUDForum. Page generated in 0.03873 seconds
