Error saving JSP file [message #68819] |
Wed, 26 January 2005 19:21  |
I have been writing a JSP file using WTP with no problems, then suddenly
I started getting an error box pop-up when I save. I started stripping
the file back to find the source of the error, and I've found that I get
the error even with a blank file. The box contains a line which says:
Updating JSP Index (An internal error occurred during: "Updating JSP
Index".)
If I click on this, I get the following information:
An internal error occurred during: "Updating JSP Index".
java.lang.NoSuchFieldError: indexLocations
org.eclipse.jst.jsp.core.internal.java.search.JSPSearchSuppo rt.computeIndexLocation(JSPSearchSupport.java:453)
org.eclipse.jst.jsp.core.internal.java.search.JSPSearchSuppo rt.addJspFile(JSPSearchSupport.java:302)
org.eclipse.jst.jsp.core.internal.java.search.JSPIndexManage r$ProcessFilesJob.run(JSPIndexManager.java:212)
org.eclipse.core.internal.jobs.Worker.run(Worker.java:66)
Can anyone tell me what is going wrong here?
Dan.
Re: Error saving JSP file [message #68936 is a reply to message #68896] |
Wed, 26 January 2005 23:59  |
Um, aren't I embarrassed now . . .
Yes I'm using 3.0.1. Somehow I've also been using WTP M2 without a hitch
up until a few hours ago, and didn't realise I was on the wrong
platform. I'll go fix that up now. Thanks.
Dan.
David Williams wrote:
> On Thu, 27 Jan 2005 11:21:47 +1100, Dan Simmonds <danoxster@gmail.com>
> wrote:
> This sounds familiar to other posts and bugs that have been opened when
> users have tried to
> use WTP M2 with Eclipse base 3.0x ... WTP M2 requires Eclipse 3.1, M4
> ... any chance you updated/backleveled
> something between the "successful use" and "not successful use"?
FUDForum. Page generated in 0.02780 seconds
