Home » Archived » Visual Editor (VE) » IWAV0138E Remote VM terminated too soon
| IWAV0138E Remote VM terminated too soon [message #68807] |
Sat, 23 October 2004 12:17  |
I have Windows XP SP2 with a fresh installed Eclipse and VE, all
versions are exactly as stated on the VE page.
I created a new project and then a visual class to test the VE but when
the VE tries to start i get this error message:
I have found 2 other postings about this topic but it seems they were
slightly different, rebooting doesn't help.
I hope that anyone has an idea because i really want to test the VE.
| Re: IWAV0138E Remote VM terminated too soon [message #68844 is a reply to message #68831] |
Sat, 23 October 2004 19:44   |
>> when the VE tries to start i get this error message:
> Please post the .log file from the .metadata directory in your eclipse
> workspace directory. This will be useful in diagnosing the issue you're
> having.
> - Jeff
OK, here we go and thanks for your response
!SESSION Okt 24, 2004 01:42:59.421
eclipse.buildId=M200409161125
java.version=1.4.2_01
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=de_DE
!ENTRY org.eclipse.jem.proxy 2 0 Okt 24, 2004 01:42:59.437
!MESSAGE
+++ Warning +++: Sun Oct 24 01:42:59 CEST 2004 Project (Test)-VM for
Test:err>java.net.ConnectException: Connection refused: connect
!MESSAGE
Test:err>
!MESSAGE
for Test:err> at java.net.PlainSocketImpl.socketConnect(Native Method)
!ENTRY org.eclipse.jem.proxy 2 0 Okt 24, 2004 01:42:59.453
!MESSAGE
Test:err>
at java.net.PlainSocketImpl.doConnect(PlainSocketImpl.java:305)
at java.net.PlainSocketImpl.connectToAddress(PlainSocketImpl.ja va:171)
at java.net.PlainSocketImpl.connect(PlainSocketImpl.java:158)
at java.net.Socket.connect(Socket.java:452)
at java.net.Socket.connect(Socket.java:402)
at java.net.Socket.<init>(Socket.java:309)
at java.net.Socket.<init>(Socket.java:124)
org.eclipse.jem.internal.proxy.vm.remote.RemoteVMServerThrea d$2.run(RemoteVMServerThread.java:617)
at java.lang.Thread.run(Thread.java:534)
!MESSAGE
Test:err>
!ENTRY org.eclipse.jem.proxy 2 0 Okt 24, 2004 01:42:59.593
!MESSAGE
(Test)-Beaninfo:err>java.net.ConnectException: Connection refused: connect
!MESSAGE
!MESSAGE
(Test)-Beaninfo:err> at java.net.PlainSocketImpl.socketConnect(Native
Method)
!MESSAGE
!ENTRY org.eclipse.jem.proxy 2 0 Okt 24, 2004 01:42:59.609
!MESSAGE
!ENTRY org.eclipse.jem.proxy 2 0 Okt 24, 2004 01:42:59.843
!MESSAGE IWAV0138E Remote VM terminated too soon. See .log file for
trace of output. For VM "Project (Test)-VM for Test".
IWAV0072I Remote VM terminated before any commands can be sent.
Following are the error and output streams.
-- Error Stream --
-- Output Stream --
Couldn't retrieve a socket from master server in 60 seconds.
-- End of Stream Output --
!ENTRY org.eclipse.jem.proxy 2 0 Okt 24, 2004 01:42:59.890
trace of output. For VM "Project (Test)-Beaninfo".
-- Error Stream --
-- Output Stream --
| Re: IWAV0138E Remote VM terminated too soon [message #68865 is a reply to message #68844] |
Sat, 23 October 2004 21:16   |
Originally posted by: myersj.nospam.gmail.com
Hmmm, are you running a firewall? The errors you are getting are the
result of not being able to make a network connection to the localhost.
Try disabling your firewall and see if it works.
- Jeff
>> you're having.
>> - Jeff
> !MESSAGE
> !MESSAGE
> Test:err>
> !MESSAGE
> !MESSAGE
> Test:err>
> at
> at
> !MESSAGE
> Test:err>
> !MESSAGE
> !MESSAGE
> !MESSAGE
> Method)
> !MESSAGE
> at
> at
> !MESSAGE
> -- Error Stream --
> at
> -- Output Stream --
> -- Error Stream --
> at
> -- Output Stream --
| Re: IWAV0138E Remote VM terminated too soon [message #68907 is a reply to message #68865] |
Sun, 24 October 2004 06:43  |
it works now, iwas really surprised that i had to add 127.0.0.1 to
ZoneAlarms trusted IPs, i thought localhost is always part of the
trusted range. I had blocked all internet access for the javaw.exe.
thanks
| Re: IWAV0138E Remote VM terminated too soon [message #602280 is a reply to message #68807] |
Sat, 23 October 2004 16:13  |
having.
- Jeff
| Re: IWAV0138E Remote VM terminated too soon [message #602286 is a reply to message #68831] |
> having.
> - Jeff
!MESSAGE
!MESSAGE
Test:err>
!MESSAGE
!MESSAGE
Test:err>
!MESSAGE
Test:err>
!MESSAGE
!MESSAGE
!MESSAGE
Method)
!MESSAGE
!MESSAGE
-- Error Stream --
-- Output Stream --
-- Error Stream --
-- Output Stream --
| Re: IWAV0138E Remote VM terminated too soon [message #602292 is a reply to message #68844] |
- Jeff
>> you're having.
>> - Jeff
> !MESSAGE
> !MESSAGE
> Test:err>
> !MESSAGE
> !MESSAGE
> Test:err>
> at
> at
> !MESSAGE
> Test:err>
> !MESSAGE
> !MESSAGE
> !MESSAGE
> Method)
> !MESSAGE
> at
> at
> !MESSAGE
> -- Error Stream --
> at
> -- Output Stream --
> -- Error Stream --
> at
> -- Output Stream --
| Re: IWAV0138E Remote VM terminated too soon [message #602302 is a reply to message #68865] |
thanks
Current Time: Fri Oct 24 02:55:04 EDT 2025
Powered by FUDForum. Page generated in 0.04779 seconds
