Home » Language IDEs » AspectJ » NPE when exporting a product with AspectJ support
NPE when exporting a product with AspectJ support [message #68804] Thu, 07 December 2006 04:16 Go to next message
Originally posted by: stephane.pipo.org
I am using eclipse 3.2.1 & AJDT 1.4.1.
I try to export a product with the AspectJ Support and I got an
NullPointerException :
AJModelBuildScriptGenerator.bundleToCP(AJModelBuildScriptGen erator:1296)
Is it a known issue ?
I also try to export deployable plug-ins & fragments with ApsectJ Support,
and it fails too.
Stephane.
Re: NPE when exporting a product with AspectJ support [message #68841 is a reply to message #68804] Thu, 07 December 2006 11:28 Go to previous messageGo to next message
Originally posted by: spyoung.uk.ibm.com
Hi Stephane.
Have a look at:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=166765
and see if you think that is the same/a similar problem. Can you give
some more specific information on your project so I can try to recreate
the exact same issue?
Steve
Stephane wrote:
> Support, and it fails too.
> Stephane.
Re: NPE when exporting a product with AspectJ support [message #68861 is a reply to message #68841] Thu, 07 December 2006 11:44 Go to previous message
Hi Steve,
Finally, I solved my issue, in my plug-in project I have some aspects
excluded from Build Path (temporarily).
It seems that the PDE "Export wizard with AspectJ support" doesn't handle
this case.
My workaround was to add a new source folder and move the excluded aspects
to this new source folder. In build.properties file, I don't select this
source folder.
Now, it works.
Stephane.
PS: I got some troubles to access "https://bugs.eclipse.org/bugs" at
office, thus I can't read the bug #166765.
Steve Young wrote:
> Hi Stephane.
> Have a look at:
> Cheers,
> Steve
> Stephane wrote:
>> Stephane.
Re: NPE when exporting a product with AspectJ support [message #595535 is a reply to message #68804] Thu, 07 December 2006 11:28 Go to previous message
Hi Stephane.
Have a look at:
Steve
Stephane wrote:
> Stephane.
Re: NPE when exporting a product with AspectJ support [message #595547 is a reply to message #68841] Thu, 07 December 2006 11:44 Go to previous message
Hi Steve,
this case.
source folder.
Now, it works.
Stephane.
Steve Young wrote:
> Hi Stephane.
> Have a look at:
> Cheers,
> Steve
> Stephane wrote:
>> Stephane.
Previous Topic:NPE when exporting a product with AspectJ support
Next Topic:performance issue with around Advice
Current Time: Sat Nov 22 12:05:36 EST 2025
Powered by FUDForum. Page generated in 0.04453 seconds
