Home » Eclipse Projects » GEF » Create a Figure not connectable
Create a Figure not connectable [message #68769] Sun, 09 March 2003 18:51 Go to next message
Originally posted by: truenoto.yahoo.com
What is the easiest way to create a Figure in draw2d not connectable?
For example, in the Logic example, how to make Ground Output Figure NOT
connectable?
Re: Create a Figure not connectable [message #68792 is a reply to message #68769] Sun, 09 March 2003 21:16 Go to previous messageGo to next message
Are you asking how to make an EditPart not connectable? By default, an
EditPart doesn't understand any request. So, it only *becomes* connectable
when you install a ConnectionEndpointEditPolicy. Without this policy, the
part will never be identified as a "target" for connection operations.
"Takumi Fujiwara" <truenoto@yahoo.com> wrote in message
news:b4gkga$gl$1@rogue.oti.com...
> connectable?
> Thanks
Re: Create a Figure not connectable [message #68943 is a reply to message #68792] Mon, 10 March 2003 11:02 Go to previous messageGo to next message
Thanks.
That tells me why a "Wire" is connectable, it install a
Could you tell me why I can not connect to "Label" but I can connect to
"LiveOutput" with a Wire? in the logic example?
Thanks.
"Randy Hudson" <none@us.ibm.com> wrote in message
news:b4gsmf$433$1@rogue.oti.com...
connectable
> > Hi,
> > connectable?
> > Thanks
Re: Create a Figure not connectable [message #68984 is a reply to message #68943] Mon, 10 March 2003 11:23 Go to previous messageGo to next message
You're right. Sorry, I used the wrong term. I should have said
GraphicalNodeEditPolicy. The things at the ends of connections are "nodes".
news:b4idcq$4id$1@rogue.oti.com...
> Thanks.
> Thanks.
> connectable
the
> > > Hi,
NOT
> > > connectable?
> > > Thanks
Re: Create a Figure not connectable [message #69272 is a reply to message #68984] Tue, 11 March 2003 11:15 Go to previous messageGo to next message
I would like to do this:
User can draw a wire between an AND gate and a OR gate, but not an AND gate
and a Circuit. I would like to show this interactively to the user, i.e.
when user clicks on AND gate to start a wire, and the he moves the mouse to
the OR gate, the plug icon shows up, but when he moves the icon to the
Circuit , it shows a STOP icon.
Where should I put this check? in the EditPolicy? or in the place where the
editpart return the connection anchor (return null, if the wire is not
allow)?
Thanks for your quick response.
news:b4ieal$5m0$1@rogue.oti.com...
"nodes".
> > Thanks.
> > Thanks.
an
> > connectable
> the
> > > > Hi,
connectable?
> NOT
> > > > connectable?
> > > > Thanks
Re: Create a Figure not connectable [message #69313 is a reply to message #69272] Tue, 11 March 2003 13:42 Go to previous message
news:b4l2gt$1pf$1@rogue.oti.com...
gate
to
the
> allow)?
The GraphicalNodeEditPolicy is being installed in CircuitEditPart's
super-superclass, LogicEditPart. If you overwrite the EditPolicy with null,
you will get exactly what you describe. So, in circuit editpart:
createEditPolicies() {
super.createEditPolicies();
installEditPolicy(EditPolicy.SELECTION_FEEDBACK_ROLE, new
ContainerHighlightEditPolicy());
//ADDED LINE FOLLOWS!!
installEditPolicy(EditPolicy.GRAPHICAL_NODE_ROLE, null);
Previous Topic:question on draw2d translateToAbsolute() and translateToRelative()
Next Topic:Simple examples ...
Current Time: Tue Nov 04 16:30:25 EST 2025
Powered by FUDForum. Page generated in 0.03041 seconds
