invisible SWT-composite when running as Bean or Application [message #68763] |
Fri, 22 October 2004 19:48  |
I've got the problem that a SWT-class shows a composite correctly in the VE
and also in that "preview-window" out of the Eclipse-window, but the
composite isn't shown when running the class as Bean or Application.
The composite is set visible and I gave it a red background-color and set a
button on it. Everything is invisible!
Perhaps you can give me a tip here?
Here is an example-class:
import org.eclipse.swt.widgets.Button;
import org.eclipse.swt.SWT;
import org.eclipse.swt.layout.GridLayout;
import org.eclipse.swt.widgets.Composite;
public class Testclass2 {
private org.eclipse.swt.widgets.Shell sShell = null;
private Composite composite = null;
private Button button = null;
* This method initializes composite
private void createComposite() {
composite = new Composite(sShell, SWT.NONE);
button = new Button(composite, SWT.NONE);
button.setBounds(new org.eclipse.swt.graphics.Rectangle(20,23,34,18));
composite.setBackground(org.eclipse.swt.widgets.Display.getD efault().getSystemColor(org.eclipse.swt.SWT.COLOR_RED));
/* Before this is run, be sure to set up the following in the launch
configuration
* (Arguments->VM Arguments) for the correct SWT library path.
* The following is a windows example:
-Djava.library.path=" installation_directory\plugins\org.eclipse.swt.win32_3.0.0\o s\win32\x86 "
org.eclipse.swt.widgets.Display display =
org.eclipse.swt.widgets.Display.getDefault();
Testclass2 thisClass = new Testclass2();
thisClass.createSShell() ;
thisClass.sShell.open();
while (!thisClass.sShell.isDisposed()) {
if (!display.readAndDispatch()) display.sleep ();
display.dispose();
* This method initializes sShell
private void createSShell() {
sShell = new org.eclipse.swt.widgets.Shell();
GridLayout gridLayout1 = new GridLayout();
createComposite();
sShell.setSize(new org.eclipse.swt.graphics.Point(300,200));
sShell.setText("Shell");
sShell.setLayout(gridLayout1);
gridLayout1.numColumns = 2;
Re: invisible SWT-composite when running as Bean or Application [message #68986 is a reply to message #68947] |
Sun, 24 October 2004 13:39  |
Rich Kulp wrote:
> There was a bug in the original New Class wizard for SWT shell (fixed in
> 1.0.1.1). It put the initialize() method before all of the settings
> instead of at the end. This causes a problem on GTK because the layout
> occurs on the setSize, but at the time of the setSize there is nothing
> to layout, so it chooses some minimal layout.
> The fix for you is to simply move the setSize to the end of the
> initialize method. Everything should work fine after this.
Fine, it works!
thanks, Rich
Re: invisible SWT-composite when running as Bean or Application [message #602310 is a reply to message #68763] |
Sun, 24 October 2004 13:16  |
Rich Kulp
Re: invisible SWT-composite when running as Bean or Application [message #602316 is a reply to message #68947] |
Fine, it works!
thanks, Rich
FUDForum. Page generated in 0.03161 seconds
