Home » Eclipse Projects » Equinox » Define extension locations using command line arguments
Define extension locations using command line arguments [message #68730] Thu, 22 June 2006 10:36
Originally posted by: newsgroups.pellaton.li
Is it possible to add an extension location using command line params?
Background info:
Our users work on different projects with different plug-in requirements
and we want to offer an easy way to switch between the configs. We
already use a separate workspace (and therefore shortcut to run Eclipse)
for each project and it would be the most convenient way to just add the
project-dependent extenstion location to the parameters in the shortcut.
I browsed the command line params file in the doc, but I have not seen
anything suitable.
Michael Pellaton
Previous Topic:ServerSide Eclipse ContractWork
Next Topic:Where is the source code for org.eclipse.osgi.services?
Current Time: Tue Jul 22 14:38:49 EDT 2025
Powered by FUDForum. Page generated in 0.02630 seconds
