XSDParser Question :( [message #68718] |
Fri, 21 July 2006 22:40  |
Hi every one:
I got a question concerning parsing an xsd file with the XSDParser class of
org.eclipse.xsd.
I used the parse method to parse a file and got a XSDSchema, and from the
XSDSchema I got XSDElementDeclarations and XSDTypeDefinitions.
The question is : how can I get the exact content of an
XSDElementDeclarations ? Coz I need to display the tree structor of the
element in a GEF application, so I must get this information.
I know an Element could be got by calling getElement(), but that way I have
to deal with a XML Element, which could be difficult to use since what I
need is the structor of the XSD file.
Any suggestion would be thankful :)
Re: XSDParser Question :( [message #68791 is a reply to message #68771] |
Sun, 23 July 2006 08:35  |
--------------030307020703020706090108
The source is packaged in the standard Eclipse way in the source plugin
that comes with our SDK zip download and can be accessed via CVS:
http://dev.eclipse.org/viewcvs/indextools.cgi/org.eclipse.xs d/plugins/
??? wrote:
> Thanks so much for your suggestion :)
> But how can I get the source code of the "XSD Editor" and "WTP's XML Schema
> Editor" you mentioned ?
> Is it included in the CVS Repositoy of Eclipse ?
> Thanks again in advance :)
> "Ed Merks" <merks@ca.ibm.com> ???? news:e9t4m6$mn5$1@utils.eclipse.org...
>> I would suggest looking at how the "XSD Editor" displays the tree
>> structure of a .xsd file in the outline view. WTP's XML Schema editor
>> displays the XSD model instances using GEF, so that's another thing that
>> might be useful. And finally, the GMF project lets you generate a
>> graphical editor from an Ecore model, so perhaps trying that with the
>> XSD model will generate something that's close to your needs.
Re: XSDParser Question :( [message #598396 is a reply to message #68718] |
Sat, 22 July 2006 08:12  |
ÕÅÏàì¶ wrote:
> Hi every one:
> org.eclipse.xsd.
Re: XSDParser Question :( [message #598403 is a reply to message #68750] |
Sat, 22 July 2006 11:55  |
Re: XSDParser Question :( [message #598411 is a reply to message #68771] |
FUDForum. Page generated in 0.03432 seconds
