Home » Archived » Visual Editor (VE) » 1.0.1.1 is now available
1.0.1.1 is now available [message #68689] Fri, 22 October 2004 15:22 Go to next message
This is now officially available and you can get it from the Visual Editor
download page http://download.eclipse.org/tools/ve/downloads/index.php.
This contains a few emergency fixes for VE 1.0, especially the well known
problem with renaming components within VE. Please see the 1.0.1.1 download page
for a link to list of bug fixes.
This is also available through the update manager. If you already have 1.0
installed, just do "Find and Install", then search for updates. Only select the
VE update, not the EMF ones.
If you have already installed the M20040929 maintenance driver, you don't need
to install 1.0.1.1 because they are the same. If you still want to install the
official 1.0.1.1 driver, do NOT use the update manager. Just download and unzip
the VE runtime (or SDK)zip over the top of your installation and start Eclipse
with the -clean option.
Regards...
Peter Walker
Re: 1.0.1.1 is now available [message #68707 is a reply to message #68689] Fri, 22 October 2004 15:57 Go to previous messageGo to next message
> select the VE update, not the EMF ones.
Thanks, Peter.
But why wh shouldn't update the EMF? Can I update it after updating the VE
and restarting eclipse?
spunti
Re: 1.0.1.1 is now available [message #68727 is a reply to message #68707] Fri, 22 October 2004 17:03 Go to previous message
Originally posted by: richkulp.us.NO_SPAM.ibm.com
All of the EMF's out there are actually development drivers for 2.0.1,
but because of the way that update manager works, it thinks they are
updates to 2.0.1. But they are actually downlevel from the official
released 2.0.1.
We have also not yet stated support for any development drivers for EMF
2.1, so those drivers aren't supported yet.
Rich Kulp
Re: 1.0.1.1 is now available [message #602246 is a reply to message #68689] Fri, 22 October 2004 15:57 Go to previous message
Thanks, Peter.
spunti
Re: 1.0.1.1 is now available [message #602254 is a reply to message #68707] Fri, 22 October 2004 17:03 Go to previous message
released 2.0.1.
Rich Kulp
Previous Topic:1.0.1.1 is now available
Next Topic:invisible SWT-composite when running as Bean or Application
Current Time: Sat Aug 30 12:58:14 EDT 2025
Powered by FUDForum. Page generated in 0.03076 seconds
