Missing steps in test behavior [message #68690] |
Wed, 26 April 2006 09:32  |
Hi all,
I think that test behavior lakcs two important steps in the behavior.
I"m speaking about test "begin" and test "end". Indeed, these concepts
exist in JUnit formality under the "setUp" and "tierDown" methods. I think
it's a mandatory step in a test suite that should be present in each test
type. What do you think about it and i'm sorry if it has already been
submitted as a feature enhancment.
Regards.
BQ.
Re: Missing steps in test behavior [message #73191 is a reply to message #68796] |
Mon, 05 June 2006 08:40   |
Yes, i'm aware about this. What i meant was to introduce this concept in
the TPTP model. Setup and TearDown methods are not specifical to JUnit
tests. Setup and Teardown (or whatever, close, end, finish, etc.) steps
should be, in my opinion, present in the TPTP behavior model as mandatory
steps, i.e. for all test types (Web, Manual, auto gui, etc.) and then
mapped to the chosen technology.
Paul Slauenwhite wrote:
> Hi Bertrand,
> In fact, the same methods (e.g. setUp() and tearDown()) are used in TPTP
> JUnit tests. The behavior of a TPTP JUnit test models the execution
> sequence and its synchronization. The methods of the generated JUnit test
> class are invoked using this behavior but still following the existing JUnit
> execution conventions:
> 1) setUp()
> 2) testMyTest()
> 3) tearDown()
> Paul
> "Bertrand Quenin" <bquenin@axway.com> wrote in message
> news:2e820e600ee5fb15e20f93b0d7856df3$1@www.eclipse.org...
>> Hi all,
>> Regards.
>> BQ.
Re: Missing steps in test behavior [message #73636 is a reply to message #73191] |
Fri, 09 June 2006 09:01   |
Hi Bertrand,
This can be modeled using the current behavioral model by creating a
test for each setup and tear down and reference these 'tests' before and
after the actual test invocation.
If this solution is not suitable, please feel free to open a TPTP
enhancement.
Paul
news:e82dc2465998ac5a373ae80cbd5bafe7$1@www.eclipse.org...
> > Hi Bertrand,
TPTP
test
JUnit
> > 1) setUp()
> > 2) testMyTest()
> > 3) tearDown()
> > Paul
> >> Hi all,
behavior.
think
test
> >> Regards.
> >> BQ.
Re: Missing steps in test behavior [message #79719 is a reply to message #73636] |
Wed, 02 August 2006 19:15  |
> Hi Bertrand,
> enhancement.
> Paul
This solution is a workaround, nothing more. I agree that it's not
mandatory to have a global "begin" and "end" step in a test suite.
Moreover, it's easily implemented in JUnit by using the TestSetup wrapper
on the Hyades test suite and providing global setUp and tearDown methods.
I was just proposing this enhancment as the TPTP model is really pertinent
and, in my opinion, it lacks these two steps, but it's ok =)
BQ.
FUDForum. Page generated in 0.04006 seconds
