Home » Archived » BIRT » eXXX methods
eXXX methods [message #68611] Sat, 20 August 2005 06:12 Go to next message
Hi!
Can anyone please explain me, why quite a lot of methods start with e?
eIsSet()
eUnset()
Thanks in advance,
Stefan
Re: eXXX methods [message #69347 is a reply to message #68611] Tue, 23 August 2005 12:13 Go to previous messageGo to next message
Originally posted by: mpadhye.actuate.com
Stefan,
I assume that this question is regarding the Chart API.
The Chart model used by the BIRT Chart Library, is created using
EMF. The 'eXXX' methods you see are the 'reflective' API that are part
of EMF generated models.
For an explanation of how these can be used, you should look at one
of the following page (in addition to the API documentation for
'EObject' in EMF):
1. 'Using the reflective API' section in
http://eclipse.org/emf/docs.php?doc=references/overview/EMF. html
Milind
Stefan Zugal wrote:
> Hi!
> eIsSet()
> eUnset()
> Thanks in advance,
> Stefan
Re: eXXX methods [message #69675 is a reply to message #69347] Thu, 25 August 2005 14:27 Go to previous message
Thanks a lot!
Milind Padhye schrieb:
> Stefan,
> 'EObject' in EMF):
> Milind
> Stefan Zugal wrote:
>> Hi!
>> eIsSet()
>> eUnset()
>> Thanks in advance,
>> Stefan
Previous Topic:Small bug: BIRT1_0_1_20050811_PATCH (Branch): When you click "Run report" button on the re
Next Topic:required plug-ins for BIRT
Current Time: Sun Aug 31 01:53:00 EDT 2025
Powered by FUDForum. Page generated in 0.03559 seconds
