eXXX methods [message #68611] |
Sat, 20 August 2005 06:12  |
Hi!
Can anyone please explain me, why quite a lot of methods start with e?
eIsSet()
eUnset()
Thanks in advance,
Stefan
Re: eXXX methods [message #69675 is a reply to message #69347] |
Thu, 25 August 2005 14:27  |
Thanks a lot!
Milind Padhye schrieb:
> Stefan,
> I assume that this question is regarding the Chart API.
> The Chart model used by the BIRT Chart Library, is created using
> EMF. The 'eXXX' methods you see are the 'reflective' API that are part
> of EMF generated models.
> For an explanation of how these can be used, you should look at one
> of the following page (in addition to the API documentation for
> 'EObject' in EMF):
> 1. 'Using the reflective API' section in
> http://eclipse.org/emf/docs.php?doc=references/overview/EMF. html
> Milind
> Stefan Zugal wrote:
>> Hi!
>> eIsSet()
>> eUnset()
>> Thanks in advance,
>> Stefan
FUDForum. Page generated in 0.23432 seconds
