Home » Modeling » OCL » Problem while serializing the OCL AST
Problem while serializing the OCL AST [message #68587] Wed, 11 March 2009 07:43 Go to next message
Hey all,
may be the last questions was not recognized, because it might be
appeared as an answer. That why i'm posting again:
I tried to serialize the parsed ast, but i got a ClassNotFoundException,
when i open the xmi with the sample reflective edtitor.
The Class "ExpressionInOcl" could not be found. I think, the connection
to the ocl.uml metamodel is lost??? Is it so?
And by the way, how can the OCL AST View be used? I don't know how to
pass an ast to it, since it seems that there is no functionality
implemented.
Thx in advance
Timothy
Re: Problem while serializing the OCL AST [message #68619 is a reply to message #68587] Wed, 11 March 2009 09:29 Go to previous messageGo to next message
Originally posted by: cdamus.zeligsoft.com
Hi, Timothy,
See my reply on the other thread. I guess I'm not as active in the
newsgroups these days ... sometimes that happens.
cW
Timothy Marc wrote:
> Hey all,
> implemented.
> Thx in advance
> Timothy
Re: Problem while serializing the OCL AST [message #68627 is a reply to message #68619] Thu, 12 March 2009 06:58 Go to previous messageGo to next message
Hi Christian,
no problem, i even just thought, that it wasn't recognized as an
question, but as an answer.
I ran this junit test as an junit plugin test, so within the eclipse
context. I even checked, whether i have referenced the required plugins.
See the list:
org.eclipse.emf;bundle-version="2.4.0",
org.eclipse.emf.ecore;bundle-version="2.4.2",
org.eclipse.emf.ecore.xmi;bundle-version="2.4.1",
org.eclipse.ocl;bundle-version="1.2.3",
org.eclipse.ocl.doc;bundle-version="1.2.1",
org.eclipse.ocl.ecore;bundle-version="1.2.1",
org.eclipse.ocl.source;bundle-version="1.2.3",
org.eclipse.ocl.uml;bundle-version="1.2.3",
org.eclipse.ocl.uml.source;bundle-version="1.2.3",
org.eclipse.pde.runtime;bundle-version="3.4.0",
org.eclipse.uml2;bundle-version="2.1.0",
org.eclipse.uml2.common;bundle-version="1.4.0",
org.eclipse.uml2.uml;bundle-version="2.2.2",
org.eclipse.uml2.uml.resources;bundle-version="2.2.0",
But the following snippet still doesn't work:
final Resource oclResource =
ocl.getEnvironment().getTypeResolver().getResource();
oclResource.setURI(outURI);
try {
oclResource.save(null);
} catch (IOException e) {
e.printStackTrace();
Thx Timothy
Christian W. Damus schrieb:
> Hi, Timothy,
> cW
> Timothy Marc wrote:
>> Hey all,
>> ClassNotFoundException, when i open the xmi with the sample reflective
>> edtitor.
>> connection to the ocl.uml metamodel is lost??? Is it so?
>> implemented.
>> Thx in advance
>> Timothy
Re: Problem while serializing the OCL AST [message #68810 is a reply to message #68627] Sat, 14 March 2009 14:26 Go to previous messageGo to next message
Originally posted by: give.a.damus.gmail.com
Hi, Timothy,
You might try comparing your code against what the
org.eclipse.ocl.uml.SerializationTest does, to see what you might be
missing. It isn't readily apparent to me.
It is interesting that the problem is with the ExpressionInOcl type.
This is one of very few cases where MDT OCL uses a Java-conventional
name for the EClass ("ExpressionInOCL" -- note the capital "CL") and
uses extended metadata to apply the OMG-defined name "ExpressionInOcl"
in the XMI serialization. Perhaps there is something amiss in the
ExtendedMetaData in your scenario? I would debug the look-up of the
EClass name in the deserialization to find out ...
HTH,
Christian
Timothy Marc wrote:
> Hi Christian,
> See the list:
> try {
> Thx Timothy
>> Hi, Timothy,
>> cW
>> Timothy Marc wrote:
>>> Hey all,
>>> reflective edtitor.
>>> implemented.
>>> Thx in advance
>>> Timothy
Re: Problem while serializing the OCL AST [message #68859 is a reply to message #68810] Sat, 14 March 2009 14:35 Go to previous messageGo to next message
Sorry, that should be "org.eclipse.ocl.uml.tests.SerializationTest"
cW
Re: Problem while serializing the OCL AST [message #68880 is a reply to message #68859] Sat, 14 March 2009 15:38 Go to previous messageGo to next message
Hey Christian,
may be you can help me, because how can i look into an test. There are
only class-files in it and no addition code. May be, i have a lack of
knowledge concerning this topic :-)
Cheers
Timothy
> cW
Re: Problem while serializing the OCL AST [message #69160 is a reply to message #68880] Thu, 19 March 2009 21:07 Go to previous message
Hi, Timothy,
Just check out the test project from the CVS repository:
/cvsroot/modeling/org.eclipse.mdt/org.eclipse.ocl/plugins/or g.eclipse.ocl.uml.tests
Christian
Timothy Marc wrote:
> Hey Christian,
> Cheers
> Timothy
>> cW
Previous Topic:Multiple output values in postcondition
Next Topic:OCLHelper questions
Current Time: Thu Jun 19 16:39:15 EDT 2025
Powered by FUDForum. Page generated in 0.03930 seconds
