Home » Archived » BIRT » i18n string in a label
i18n string in a label [message #68566] Fri, 19 August 2005 17:51 Go to next message
Hello group members,
Can someone give a tip on how to display a i18n string in a label?. The
i18n string to show depends on the value of a report parameter. For
example, if the parameter "datatype" is "M" I want to show the string
"Measured" or "Medido" depending on the current selected localization, if
its "R" it should show "Reconciled" or "Reconciliado".
Thanks in advance,
Javier
Re: i18n string in a label [message #68603 is a reply to message #68566] Sat, 20 August 2005 02:11 Go to previous messageGo to next message
Originally posted by: g.ewald.arcor.de
Hi Javier,
for the use of language specific ressources please have a look at the
class java.util.RessourceBundle.
With this class you can specify message ressoucefiles in a
key-value-pair-style and load it specificly for a locale.
Best regards
Gregor
Javier Pedrido schrieb am 19.08.2005 23:51 folgendes:
> if its "R" it should show "Reconciled" or "Reconciliado".
> Thanks in advance,
> Javier
Re: i18n string in a label [message #68617 is a reply to message #68603] Sat, 20 August 2005 13:35 Go to previous messageGo to next message
Originally posted by: javierpedrido.hotmail.com
Hi George,
Thanks for your help. I already knew about the ResourceBlunde class. I was
looking for a method to do the i18n without having to instantiate this
class. For example, it might be usefull to have a getMessage method in the
report class in order to access strings included in its i18n resource
files. Having the ability to show i18n text when displaying parameters
values in a combo box and when mapping values, would be great also. I
guess these i18n "problems" will be addressed in future versions.
Javier
Re: i18n string in a label [message #68715 is a reply to message #68617] Sat, 20 August 2005 13:41 Go to previous message
Javier Pedrido wrote:
> Hi George,
Sorry about the misspelled name Gregor ;)
Thanks for helping,
Javier
Previous Topic:engine API example
Next Topic:how to set a background image on the whole report or body?
Current Time: Fri Nov 21 17:35:03 EST 2025
Powered by FUDForum. Page generated in 0.14653 seconds
