| Re: Install/Getting Eclipse to open the BIRT perspective [message #68576 is a reply to message #68557] |
Fri, 19 August 2005 22:18  |
Igor Katraev wrote:
> Ram wrote:
>> I have followed the instructions on the BIRT install page. However, I
>> do not see the BIRT perspective. What am I doing wrong?
> I have it worked just yesterday. Are you able to create BIRT projects,
> BIRT reports? Is BIRT designer accessible for you?
> What Eclipse version are you using? Have you installed all plugins?
> You have to provide more details if you want somebody help you.
> Sincerely,
> Igor Katrayev.
The install instructions from the BIRT site should work with the
exception that you'll need to move the stuff from the
birt-report-framework into the correct eclipse directory.
I did run into one issue that you might want to check on. When you
unzip the emf-sdo-runtime, it'll ask you if you want to overwrite
epl-v10.html and notice.html. Say YES. I wasted a couple of hours not
getting BIRT to show up when I just manually copied the contents of
plugins and features.
If anyone knows the reason for this, I'd be glad to hear it. I suspect
it's a license thing with the EMF, but in an HTML file...?
FUDForum. Page generated in 0.06186 seconds
