Home » Modeling » GMF (Graphical Modeling Framework) » Better error diagnostics while generating model?
Better error diagnostics while generating model? [message #68517] Tue, 24 October 2006 09:37 Go to next message
Originally posted by: eduard.rindt.logicacmg.com
I would like to ask for a help with fixing errors inside the GMF Mapping.
I'm quite new with the GMF stuff and I can't get through some errors I've
made somewhere inside the Mapping. When I start computation of the generator
model, I get four times a message
Top level node 'Containment Feature' must be available in the diagram
'Domain Element' or its super-class.
It nicely describes a reason, but I have absolutely no idea where to fix it.
I do not see any "Containment Feature" unfilled anywehere among the mapping
definitions.
Is there a way to get more specific info, please?
regards,
Eduard
Re: Better error diagnostics while generating model? [message #68528 is a reply to message #68517] Tue, 24 October 2006 09:46 Go to previous message
Originally posted by: tobk.gmx.de
news.eclipse.org wrote:
> Mapping.
> I've
> generator model, I get four times a message
> it. I do not see any "Containment Feature" unfilled anywehere among the
> mapping definitions.
Do you have any containment features with the same name? in that case it's
dificult to discriminate between these two. IIRC, there's a null element
in the drop down list, too, and all the elements above this null element
(empty line) are features of the given parent class while the features
below the empty line are features of the given type, but in other parent
classes, so you should pick one from the upper half of the list.
If you double-click the Error in the Problem View you are brought directly
to the error's location.
> regards,
> Eduard
tobias
Previous Topic:Is the Flow- or GridLayout supposed to work???
Next Topic:Correct import
Current Time: Tue Jul 22 06:34:11 EDT 2025
Powered by FUDForum. Page generated in 0.52970 seconds
