Home » Language IDEs » Java Development Tools (JDT) » How to obtain the absolute path of the workbench installation
How to obtain the absolute path of the workbench installation [message #68458] Thu, 26 June 2003 21:49 Go to next message
Originally posted by: lebowitz.finaltouch.com
I'm trying to obtain the full, absolute path of a subdirectory in one of my
custom plug-ins using the jdt API. I've only managed to obtain a relative
path using the getDescriptor().getInstallPath() method, but what want is the
full path to that directory from the file system root....
I'm guessing that there is some way to determine where the workbench is
installed within the local file system programmatically.... can someone help
out here???
Rob
Re: How to obtain the absolute path of the workbench installation [message #68471 is a reply to message #68458] Thu, 26 June 2003 22:23 Go to previous messageGo to next message
Originally posted by: burner.zclipse.org
> my custom plug-ins using the jdt API. I've only managed to obtain a
> relative path using the getDescriptor().getInstallPath() method, but
> what want is the full path to that directory from the file system
> root....
What about getInstallURL()? That's what I always use whenever I need to
get at stuff in my plugin's directory.
> help out here???
It's not meant to be easy, as far as I can tell. I don't believe it's
quite possible yet, but the idea is that a plugin might very well have
been loaded off a web server and so there might not be any such
installation point in the local directory.
> Rob
Re: How to obtain the absolute path of the workbench installation [message #68968 is a reply to message #68471] Fri, 27 June 2003 11:07 Go to previous message
Originally posted by: richkulp.NOSPAM.us.ibm.com
See
http://eclipsewiki.swiki.net/114#platformurl
Wiki seems to be running really slow today though.
Rich
Previous Topic:org.eclipse.jdt.debug.core [API Help]
Next Topic:Generate getters and setters
Current Time: Fri Nov 07 03:33:25 EST 2025
Powered by FUDForum. Page generated in 0.23695 seconds
