Home » Archived » XML Schema Definition (XSD) » Schema validation problem
Schema validation problem [message #68454] Tue, 27 June 2006 02:13 Go to next message
Originally posted by: An.nym.us
Hi I have a questoin concerning XSD Schemas in XML:
I have some > 30 XML files, that use a specified XSD for validation.
This XSD is specified with relative pathname.
I the lifetime of the XML and the corresponding XSD they change location
1. Source Control System : Split into various modules and generic base
files.
2. CD (Deployment) : Some of the modules and configuration
variations of speciel modules.
3. Installtain (HDD) : One conffiguration with some defined modules,
all in the correct location.
As the XSD Path is specified as relative path in the XML this means I can
only validate the XML after installation, which is not very good.
Can somebody suggest me alteratives / ideas what features of XML / XSD to
use to validate in each process. With alternating XSD locations ?
Could a approch of a namespace help us ?
Thanks for hints.
Erstellt mit Operas revolutionärem E-Mail-Modul: http://www.opera.com/mail/
Re: Schema validation problem [message #68519 is a reply to message #68454] Tue, 27 June 2006 15:21 Go to previous message
Sascha,
Are you saying the XML files using xsi:schemaLocation to refer to the
XSD with a relative path? In the WTP (Web Tools) project they have the
notion of an XML catalog that lets you specify that a particular target
namespace corresponds to a particular physical schema location. With
this approach, you wouldn't need an xsi:schemaLocation...
> base files.
> modules, all in the correct location.
> can only validate the XML after installation, which is not very good.
> to use to validate in each process. With alternating XSD locations ?
> Thanks for hints.
Re: Schema validation problem [message #598302 is a reply to message #68454] Tue, 27 June 2006 15:21 Go to previous message
Sascha,
> base files.
> Thanks for hints.
Previous Topic:model editor appearance customization
Next Topic:Schema - Versoin Control
Current Time: Tue Oct 28 11:14:08 EDT 2025
Powered by FUDForum. Page generated in 0.58864 seconds
