Home » Language IDEs » Java Development Tools (JDT) » How to add a directory to project classpath?
How to add a directory to project classpath? [message #68404] Thu, 26 June 2003 18:09 Go to next message
I am working in WSAD 5.0 (i.e. Eclipse 2.0 + IBM plugins). I want to add a
configuration directory to the project classpath. The tool very diligently
foils all of my attempts. What is the right way to do it?
Thank you,
Yan Gulko
Re: How to add a directory to project classpath? [message #69094 is a reply to message #68404] Fri, 27 June 2003 15:01 Go to previous message
> Thank you,
> Yan Gulko
If the configuration directory is only needed at runtime time then when you
click on Run->Run
Click on the application that is configure to run.
Click on the "Classpath" tab select uncheck the "Default classpath"
checkbox.
Choose Advanced->Add folders/Add external folders and browse to the required
directory.
Previous Topic:Problem: Export, eclipse's compiler and Java 1.4
Next Topic:javac option?
Current Time: Sat Nov 08 08:21:42 EST 2025
Powered by FUDForum. Page generated in 0.12867 seconds
